Question about Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier
CUR is showing on the display
The negative speaker wire must have touched the power block and now amp is not working. tried all i can think of but i think its stuck in a protect mode or something, and CUR is all it shows on the display. how can i reset the amp or do you have any suggestions in how i can repair this?
  • lil_kid36 Feb 06, 2009
    i know i wouldnt let my wires touch + to- all i did was change my battery fuse size to a 50 it was a thirty and now it blinks CUR and i cant stop it.
  • rav_uk May 21, 2009
    I have MRD M605 and the CUR is blinking on the amp. i disconnected the
    power but is still the same and the amp its still
    flashing CUR. All inline fuses are ok. There is only the +, - and the
    remote cables connected to it. I noticed the fan inside is not
    spinning! Any ideas on fixing it?
    Problem Solver:
  • 12 Answers
The amp will reset when you cut the power off to it. Disconect bat for 30 sec and reconect. But to be honist with u if the wire jumped out and grounded some how during a high level, there is probley internal damage done.
Posted on Oct 23, 2008
I have a power acoustik bamf 2000 class d amp and i think when i had it unhooked the positive and negative speaker wires might of touched for a few minutes and now the amp comes on no protection light just...
internal components are very sensitive to things like that. sounds like you shorted out some of the fets internaly .. i recomend a complete diagnostic and proceed to repairs.
May 06, 2010 | Power Acoustik SL2-2000 Car Audio...
I have an alpine mrd-m1001 getting curr message ho do you reset the amp
Hello deeprajm,
Shorted or low impedance outputs can cause the "CUR" display. Power down everything and remove the speaker wires. If it will then power up without the display, the problem is probably a short in the speaker wire or voice coil, or the impedance load is too low. If there are multiple subs, reconnect them one at a time to isolate the bad one and then correct the problem. If the amp works properly with either of the subs but not both, rewire the subs for a higher final impedance.
If the amp still displays "CUR" with the speakers disconnected, there's most likely an internal fault that requires component level repair.
Hope this helps.
Aug 01, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
How do you get it out of cur mode
Hello whatup_132,
If the M605 fails and displays "CUR", it means that there is excessive current to the amp.
The most common causes for excessive current draw is operating the amp into a lower impedance than it is rated to handle, shorted speaker voice coil(s), and/or shorted or grounded speaker wires.
The amp can operate into a load no lower than 2ohms. First power everything off and disconnect the positive amp power lead temporarily (easist way is to just pull the fuse). At this point you should ONLY have the ground and remote connected. Reconnect positive (insert fuse) and turn on the vehicle ignition and your head unit. If the amp still displays the "CUR" error, the output MOSFET's are probably defective and the amp requires repair or replacement. If it powers up normally, reconnect the speaker wires until you locate the faulty one, and then correct whatever is causing it.
Hope this helps.
Jul 17, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR display
Hello yte1771,
You can download the manual from Crutchfield.
The "CUR" display is an indication of excessive current and is most likely caused by too low impedance or a fault in the wiring or the amp itself. It's probably not your cap.
Hope this helps.
May 18, 2009 | Alpine MRD-M605 Car Audio Amplifier
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR showing on the display
This means too much current, find and eliminate cause of excessie current and turn power off, also possibe power and ground are not big enough .Recommend 4guage wires
Oct 17, 2008 | Alpine MRD-M605 Car Audio Amplifier
Overcurrent protector
The woofer or the wiring may be shorted. Remove the speaker wires from the terminals of the amp and power up the amp. If it powers up, check the wiring and the speaker. If it still goes into protect, the amp may be defective. A short in the wiring or speaker can damage a brand new amp.
Dec 17, 2007 | Sony XM-1600GSD Car Audio Amplifier
Have you measured the DC resistance of the woofer to determine if it's OK? You will need to disconnect it from the amp. Check each voice coil individually.
If you disconnect both speaker wires from the amp, does it still show an overcurrent condition?
Oct 20, 2007 | Alpine MRD-M605 Car Audio Amplifier
Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier Logo
397 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
