Question about Panasonic DMR-ES30VS DVD Recorder/VCR
My dmr-es30v is dead
My unit was working fine and then I went to turn it on one day and nothing happened. I've verified there's power to the unit. I took off the case and looked things over, no signs of any loose connections or other problems. I'm in South Korea, so the options are very limited. I found a Panasonic repairman, but he said that he didn't have any parts for it and that it would be to costly to even look at it. Is there possibly a very simple solution?
Hoping,
Rick MIller
  • 4 Answers
Check the circuit boards inside again. Look for swollen capacitors (small "cans" sitting on end). If the top is swollen up and not flat, that is probably the problem. You can get a substitute capacitor easily. Radio Shack even has some. Check the CD Freaks web site for a video solution.
Posted on Jan 08, 2009
Panasonic dmr-es30v will not turn on
The circuit board may look good, but a power surge can damage the tiny resistors, diodes, and transistors. Any one of those mention can render the unit inoperable.
Feb 27, 2014 | Panasonic DMRES30V DVD Recorder/VCR Combo
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
I have a Panasonic DMR ES30V DVD/VHS recorder. Sometimes the DVD recorder will stop (generally in the first 30 seconds) and a Check light will show. I then have to shut down the unit and restart. ...
I had the same problem with my DMR-E30VS. I tried a disk cleaner, that did not work. I took the cover off cleaned the lens witk a Q-tip and Isopropyl (rubbing) alcohol. It works fine now!
Jun 28, 2011 | Panasonic DMR-ES30VS DVD Recorder/VCR
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
My dvd player is dead.
You check the SMPS (Power Supply Section) and verify the voltages from the various terminals of the transformer accordingly check the bridge, voltage regulator, and filter circuits. If any of this parts are gone replace the appropriate parts not the all.
Jul 25, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
How do I tell if my unit (Panasonic DMR-ES30V) is multizone?
This unit will play either Region 1 or Region "ALL" discs.
-Tha Mp3 Doctor
Dec 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR Logo
390 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
