What is the dot pitch on Hitachi Superscan Pro 800?
  • Computers & ... Master
  • 787 Answers
.22 mm
Posted on Oct 17, 2008
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
Why does Image on tv screen sags in top left
buy a new monitor its a problem with the photon beam
May 08, 2010 | Hitachi SuperScan Elite 802 21" CRT...
Took it apart, reassembled, stopped working. Hitachi superscan elite 751
All fixed. Discovered 3 setting screws. 2 for focus, one for picture. Monitor must be running with plastic casing removed to access set screws and adjust till perfect.
Jan 28, 2010 | Computers & Internet
MY HITACHI CUT OFF YESTERDAY BY ITSELF. THEIR ARE THREE INDICATOR LIGHTS ON THE RIGHT FRONT LOWER PART OF THE TV, AND THE TOP ONE IS STAYING ON. YOU PRESS THE POWER BUTTON AND IT TRIES TO COME ON, I GUESS...
Shorted Hori ouput Transistor near FBT flyback Transfomer.Go towebsite online Encompass Parts Distr. they have listing for your Tv also have service manual,or Call 1-800-638-3328
Nov 19, 2009 | Hitachi 55FX48B 55" Rear Projection...
Need a driver for superscan pro 800
the monitor doesn't need a driver, you are most likely missing display adapter drivers from your computer or can you explain why do you need a driver for your monitor? I've never installed drivers for my monitors in the last 10 years.
May 21, 2009 | Hitachi SuperScan Pro 800 Monitor
Whats the solution
at the vertical stage of the tv there is a capacitor that is weaken and need to be replaced.
do this by testing all the capacitors on that stage.isolate it and replace it with the same type
Apr 10, 2008 | Hitachi SuperScan Elite 802 21" CRT...
Technic's 1210M5G problem with the pitch slowing
Sounds like your pitch control is about to go bad. I would suggest replacing it. The part can be purchased HERE.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 25, 2008 | Technics SL-1210M5G Turntable
I need a remote Code
The comcast remote control code for Superscan VCR/DVD combo is 11963
Dec 27, 2007 | Televison & Video
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
