Question about Motorola Mobility RAZR V3
Phone will charge but i have to move the cord around so it will charge
When i plug phone in to charge dose not charge for it to charge i have to move the cord around then it get a charge and i move it up by the chargeing port mine is a usb charger i dont know what to do help ????
    Sniper:
  • 66 Answers
Im sure the primary problem with your phone is within your charging terminal/charging port. It needs to replace a new one, maybe because it might losen or partially damage.You should bring your phone to a cellphone service shop and ask them if they have a charging terminal/charging port just like yours and let them replace the new one. Also try insert your phone to a different charger that you sure that is ok, observe if desame happens. We can't ignore also that it might be the charger that has the problem. Was this solution/advise helpful to you? You can send me email at st_nardz@yahoo.com for my further assistance. Kindly rate this up! thank you.
NARDZ
Posted on Oct 17, 2008
How do I fix a cellphone that won't charge at all when it is plugged in. I've tried turning it off, taking the battery out, and everything.
It could be a problem with the female usb port on your phone. Try shining a light inside where you plug it in and see if there is anything there. Here are a few phones with the female ports where you plug in your charger.
25894004-w32j5maowckw4u0pbavragxd-2-0.png Use something like a toothpick to clean out inside there. If you use something too hard, it can damage the inside of the port.
If there is nothing in there, it could be the cord. Have you tried multiple cords and cubes (wall adapters)? Here is the iPhone version, but really all that changes is the business end of the charging cord, so it still applies.
25894004-w32j5maowckw4u0pbavragxd-2-1.jpg If you have tried multiple combinations of cords and wall adapters, then it might be that the charging port on your phone is broken and needs repairing. A sign of this being the case could be the cable being able to wiggle around too much when plugged into the phone.
If these other solutions do not work, you may need to replace the female micro/mini usb port in your phone, which could be above your skill set and you may need to hire a professional, or someone who knows their way around a soldering iron.
Oct 05, 2015 | ZTE Cell Phones
My phone will not take a charge or power up
Confirm that the charging port is working (it may have cable connection issue, and have to be place in a certain position to charge), If the port is fine, then figure if battery is bad.. If charging port is bad, its a relatively easy and cheap fix.
May 29, 2014 | HTC Vivid
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
When i plug in the charger it charges but dose not recognise that the charger is incertetd
turn phone off and you will see 'battery charging' or if left on, the battery icon should flash. Some models will make a sound when cord is plugged in
Feb 15, 2011 | LG GW525 Cell Phone
My phone wont stay charging. I have to pull the cord tight and at an angle to get it to stay charging. this is with my home charger. Any other problems with plug or chargers?
Sound like the terminal on your phone is broken off internally. the soldier of the pins are bad thats why you have to move it around to get it to connect. You can see if there is a local repair shop in your area that does port repairs. hope this will help.
Oct 23, 2010 | Casio G'zOne Boulder Cell Phone
My laptop xps 1530 battery not charging
The battery is stationary but the cord is not, so I would say it is the cord. Go top a good store that works on them and ask to try it before you buy it. A new power supply can run $60.
Jul 19, 2009 | Dell XPS M1530 Notebook
Its a metro and it purple
Check the charger for output voltage.
2. Clean the charger contacts in the phone with a q-tip and a little rubbing alcohol.
3.Check the cord on your charger for cuts, breaks etc.
4. If it's a car charger, check the outlet in the car for voltage, check the cord's fuse in the handle,
5. Check the battery-to-phone contact connections for cleanliness, tarnish,
6. replace battery with new.
Let me know how you do...
Jul 03, 2009 | Pantech Matrix Cell Phone
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Motorola Mobility RAZR V3 Logo
135 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
