Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 Laptop
I have Acer Aspire 5610 Laptop. I Cannot install XP SP2 in it. It only boot from Win98.After installing win98 it always show 1 & 2 of it's files are missing.
    Problem Solver:
  • 20 Answers
If it had vista installed first then u are sol, unless u use a new hard drive. That is probably why your cam and several other things don't work. The laptop was designed for VISTA.
Posted on Oct 19, 2008
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
I m unable to install xp proffesional sp2 on my acer aspire 4710.
this is what you do, on the cmos setup, device configuration, you will see sata HDD ..., disable it and try and reload the OS again
Jul 14, 2009 | Acer Aspire 5610-4648 Notebook
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
Cant Find XP Audio Drivers & modem for Acer5720Z
Use the below link to download all the drivers for your Acer 5720z
Acer 5720Z Driver
Was this solution helpful .Show your appreciation by rating it.
May 30, 2008 | Acer Aspire 5610-4648 Notebook
Cannot Re-install Windows from Recovery DVD's ACER 5610-4179
Your recovery disks must be scratched or files are corrupted. Since you have successfully installed XP Pro, why not stay with it as it's better than Home?
If you have a restoration partition on your C drive, you may be able to revert to your original configuration from it. And if you insist on XP Home or only have a valid product key for home, you can borrow a disk from anyone who has a good copy.
I hope this helps.
Mar 18, 2008 | Acer Aspire 5610-4648 Notebook
Windows98 hp
if there is a dump of win98 in the drive c of your laptop
the go on command prompt
c:\>cd win98 Enter
c:\win98>setup Enter
and repair the win98 without any loss of data
second install antivirus and update properly the scan al the system
Mar 14, 2008 | Acer Aspire 5050-3242 Notebook
Dual boot
hi wtm78 this is nichu,
it is impossible to install win 98 after installing xp,if you want to install win98 you must remove the winxp and then first install win98 and later you can install winxp,
basically it is impossible to install a lower order software when xp is already installed,in your case it is the same
there will be no things like dual boot or anything ,after booting your system asks whether you want to work with win98 or winxp.
be cool.
take care
bye and have a nice day.
Nov 08, 2007 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
