Question about Watches
Cleaning my watch
How do I remove the winder to clean my rotary GB0768?
    Champion:
  • 203 Answers
Are you sure you want to. i would not advise it unless you are qualified to . hope this helps
Posted on Nov 21, 2008
How do i remove winder stem from rotary skeleton watch
OPEN UP THE BOTTOM AND STICK A SMALL THIN PAINT BRUSH IN AND WIPE IT CLEAN I HAVE DONE IT A FEW TIMES
Nov 18, 2016 | Rotary Watches
What kind of watch winder do I need for this watch
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction).
AUTO-WIND function is NOT at all unique to your watch...
After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly)
MTE watch winder (their very basic WTS-4).
Good luck: I WILL try to include the URL (see page 6)
http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
Dec 06, 2015 | Tag Heuer Watches
Self whinder starts then stops after a couple of seconds ???
If you have had it for a good while, it probably needs a cleaning. And a little lube to keep it ticking.
Apr 30, 2014 | Rotary Watches
How do I remove the winder from Pierre Cardin Diamonds watch? I think the waterproof seal has perished and have condensation on face that needs to be cleaned off. There appears to be a 'collar' at...
Better get it dried up and serviced asap, as the moisture might have got into the movement. You dont want rust to be your next problem. But, some screw some dont....most people bring in the crown in one hand and the timepeice in the other-broken. If I'm thinking of the right watch, there is a release point inside the case that releases the stem.
Aug 23, 2011 | Pierre Cardin Pierrecardin Diamonds...
Remove links rotary watch braclet
am given you the watch service center link you go on the site and follow the instruction and resolve your problem
http://www.rotarywatches.com/en/service/rotary-watch-servicing
Jan 10, 2011 | Rotary Rocks Chronograph RLS00042/07 Watch...
Elgin 18s pocket watch (1908). Will not wind, ratcheting on winder sounds weak and watch will not start, This is a stem winder and set watch. will set time properly and the winding stem (internal seems...
Sounds like a broken main spring.
This is a fairly easy fix and may also be due for a cleaning and service.
Find a local repairman in your area.
http://www.nawcc.org/business-directory/
Hope this tip helps
R/
David
Feb 14, 2010 | Elgin Watches
Breitling watch winder rotations requirments
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
Mar 13, 2009 | Breitling Chrono Cockpit 164-Pilot Wrist...
Winder on Rotary watch
Open the watch and lay it on the table dial down and winder facing you.
Get the hard steel needle and push down the small metal piece next to the to the place where the stem is entering the movement (on the left side). Pull out the stem while holding that piece down.
If thhat piece looks like screw cap (with the groove), then you have to unscrew it in order to get the stem out.
Do not forget to rate, please.
Mar 01, 2009 | Watches
Rotary watch
place the back plate in the freezer till its really cold itll snap right in there:)
Oct 17, 2017 | Timex 27191 Wristwatch
Watches Logo
398 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
