Question about Honeywell Heating & Cooling
Honeywell Controller RM7840L preignition interlock
Buenas noches soy de ecuador si porfavor alguin me puede ayudar con diagramas para instalar el controlador rm7840l en una caldera que antes tenia un controlador r4140l
no se cuales son los sw high fire purge y low fire start
gracias
Posted on Sep 22, 2010
Tip
Troubleshooting Guide
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Mar 30, 2008 | Kenmore 80412 Microwave Oven
How does one wire a 24 volt White-Rogers evaporative cooler controller replacement for an ancient mercury switched Honeywell controller?
Red wire, R with a jumper to RH
White , W
Green, G
Yellow, Y
Make certain you understand thermostats come setup for gas, so pay attention to what your heat/cool unit is, that's very important, also make sure to shut off the power to your system before removing the thermostat.
Jul 08, 2014 | Honeywell Heating & Cooling
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
Flashing star on honeywell air controller, and air wont work
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 27, 2010 | Heating & Cooling
Manual for Honeywell oil-fired boiler controller
Here is a tip that tells you how to get a manual for most any Honeywell product online...
heatman101
Sep 23, 2010 | Heating & Cooling
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
I cleaned the cells on my Honeywell electronic air cleaner and now it won't run. The CHECK led is lit. Got any ideas?
Make sure the furnace or air conditioner blower is running.
Make sure the access door is firmly closed and latched. If door is not closed properly, an interlock keeps the air cleaner off.
Jan 13, 2010 | Honeywell (F50F1032) Air Purifier
Heating & Cooling Logo
287 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
