Question about Asrock 775Dual-880 Pro Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
P4vm800 cannot detect SATA HDD 250gb.
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Posted on Mar 02, 2009
With geforce 4 Ti 4600 graphics card P4VM800 does not boot.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 20, 2011 | Asrock P4VM800 Motherboard
Motherboard asrock P4VM800, we have checked and replaced everything with known good Ram, PSU, heatsink. We have confirmed that everything is connected correctly. when you power on the unit the cpu fan...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 05, 2011 | Asrock P4VM800 Motherboard
I want to upgrade my cpu for this mother board from 1.8 ghz to 2.8 ghz. What cpu should I go with. Am I going to run into problems with the bios or anything else. Also need to know if I can upgrade...
Here is a link for your mobo
http://www.asrock.com/MB/overview.asp?Model=P4VM800
looks like you can use any intel processor as long as its a socket478 by intel
Check out nvidia agp cards at www.nvidia.com You can get a 512mb card agp.
The bios is plug and play which should not be a problem.
You may need to upgrade the memory also.
Mar 22, 2011 | Asrock P4VM800 Motherboard
My motherboard have slot AGP V2.0?
Yes, it supports up to AGP 8X but needs to be at 1.5 volts and not 3.3...Here is the manual:
http://www.coj.go.th/techno/Replase-Computer/48-supreme/P4VM800.pdf
Jun 06, 2009 | Computers & Internet
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
Motherboard sata driver p4vm800
Hi ben,
you can download that driver by clicking on this link:
http://www.asrock.com/mb/download.asp?Model=P4VM800&s=478
You make a floppy disk with this driver & during windows install you watch the bottom of the screen & press F6. Windows will ask you to insert the floppy disk. (Do not forget to remove the floppy disk).
Good luck Ben!
Mike
Aug 11, 2008 | Asrock 775Dual-880 Pro Motherboard
Help! Asrock MOBO P4VM800...
There may be something wrong with the HDD. Try it in another computer to make sure it is functioning properly.
May 05, 2008 | Asrock P4VM800 Motherboard
Driver for Asusrock p4vm800 Motherboard...
Found these for you.. and a Manual also. www.asrock.com/support/download.asp?Model=P4VM800 www.judiciary.go.th/techno/Replase-Computer/48-supreme/P4VM800.pdf
Aug 15, 2007 | Asrock P4VM800 Motherboard
Asrock 775Dual-880 Pro Motherboard Logo
2,228 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
