Question about LG 42LG50 42 in. LCD HDTV
Blanck screen I'm having an issue with the tv not displaying any imagens, can't even get the input menu to come up. I tried unplugging/rebooting to no effect
    Scholar:
  • 86 Answers
Usually when the OSD will not come up, you are looking at a problem with the video boards. Is the power button flashing or showing a different color, or does it look normal in the On position. If it's flashing, then the problem lies with the mainboard not powering up properly. It might not hurt to try a power drain at least:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this doesn't work, the TV will likely require service.
Posted on Oct 17, 2008
When I turn off my vizio 55 in smart tv, which is 11/2 yrs oldthe screen goes gray and does not shut off completely. Only input cable w/o cable box.
Try unplugging it for 10-15 minutes then plug it back in and try it again. If that still doesnt work resetting it then its most likely a software/firmware issue with the mainboard. Smart tv's are not so smart. Its like having a computer and tv built into one. Sometimes they just need a hard reboot to clear an issue. If that doesn't fix it see if there is an update available for the tv's firmware, usually in the setup and service menu on Vizio smart tv's.
Dec 31, 2017 | Vizio Televison & Video
Zenith converter box
Unplug everything from the wall-outlets, and from other devices, and then reconnect all the wires.
Also, try a different TV (some newer computer-screens have "TV-input" and/or "HDMI-input" sockets).
May 20, 2014 | Televison & Video
JVC 52 inch tv, about 8 years old has sound but no picture and WE CAN read the cable guide on teh tv screen......please help! Thanks so much!
Try another input on the set, if you have on screen display set is working to some degree, also try to unplug set and or box or other gear hooked to it for a while and power back to allow all to reboot or try to===problem is NO video or no rastor if menu comes on screen. Also please check which input the set is currently on......
Oct 30, 2012 | JVC Televison & Video
I am trying to conet my computer to my tv to see movies I have the Hdmi cable but all i get is a blanck screen
Make sure your putting the TV on the correct input. Also you might need to right click on your desktop and go into your display properties to turn on your second screen.
Sep 13, 2010 | Televison & Video
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
Screen shows several horizontal and vertical lines.
this can be in your video cable or LCD Connector issue. but most problem is in the flex cable of LCD. some other cases cannot be fix and replace new LCD Screen.
Aug 14, 2009 | Samsung HP-S4253 Television
Plasma tv has no picture but green led is on
If you are not able to bring up the TV's onscreen menu while the picture is blank, then you have a problem with a video board.  If the menu does come up then usually the problem is with the device connected or its related input jack or cable that is in use. You may have to try another input or cable to be sure, but only if you are not able to see the menu.
Mar 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Blue Screen in TV Mode
I have an Audiovox FPE1506DV with the same problem: it plays DVDs okay, but when I try to watch TV, it only shows a blue screen, but sometimes you can hear the sound. Cable input is fine.
When going through the Menu option in TV mode, the "Display" option is disabled; you cannot select it with the remote.
SOLUTION: I unplugged the device for about 5 minutes, plugged it back in, and it has been working fine ever since. It's a very strange problem, but rebooting by UNPLUGGING (not just powering down) seems to have fixed it.
Dec 09, 2008 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LG 42LG50 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
