Question about 2wire (1000-400108-001) Router
I HAVE A COMCAST WIRELESS ROUTER THAT I AM TRYING TO USE TO CONNECT MY PC TO THE INTERNET. I TOOK THE COMCAST ROUTER AND PLUGGED IT INTO MY PC AND IT HAS THE GREEN LIGHT ON HOWEVER IT WON'T LET ME CONNECT TO THE INTERNET.I HAVE AT&T AS MY PROVIDER AND FOUND THE COMCAST BOX. IS IT POSSIBLE TO USE A COMCAST ROUTER TO CONNECT MY PC WITH OUT IT BEING DIRECTLY CONNECTED TO THE DESKTOP? HELP I'M STUCK AND OUT OF SOLUTIONS OF WHY IT DOESN'T OR WON'T WORK...
  • 787 Answers
You have a lot of different things going on here.
First, your provider is AT&T so you have ADSL service.
Comcast supplies their service over cable.
AT&T should have provided you with an ADSL modem that is connected to a phone wire. Normally another cable (ethernet, patch, RJ45, Cat5) connects the modem to the network card in your computer.
I don't know what model of router you have but there are 2 possiblities as to type. It can be a regular wireless router or it can actually be a cable modem with a built-in router.
If this is a normal router it will have a port labelled either Internet or Wan (normally, some companies do strange things), you should connect the cable from the ADSL modem to this port.
If it does not have a Internet or Wan port but has a round screw type cable connection, you have no way to connect this to the DSL modem and it will not work for you unless you switch to a cable provider. Even the it may not work because some providers check the MAC address of the unit and will not issue it an IP address unless it matches the one in their files.
Ok, lets say this is a normal wireless router. You have the phone line going to the ADSL modem and then a Cat5 cable going to the Wan port of the router, you are not out of the woods yet because most desktops do not come with wireless hardware. You need to get a Wireless PCI card and install it or if you prefer they also come in USB.
Done? Probably not. If this was a used router it was probably configured at one time and you will not be able to connect to it unless you happen to know the security key. This means you will have to reset the router back to factory default and configure it from scratch. Of course you could luck out and security was never configured for this router but you should still configure it unless you want everybody within range to be able to connect to your router and possibly your computer.
If after this long winded explaination you still want to do this, get back to me with the specific make and model of the router and what operating system you are using and we can go from there.
Posted on Oct 17, 2008
I have a wireless-n 150 router. I have tried to use it with a Toshiba Windows Vista computer and I cannot get the wireless to work. I have unplugged it and plugged it back in and that doesn't do it. The...
The wireless router needs to configured with the wireless settings, SSID, encryption etc. Then the wireless card in the Toshiba needs to be configured with the wireless router's SSID, encryption etc.
To secure your wireless router from unauthorized access and to configure the wireless card in your computer so it can connect to your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 11, 2010 | Office Equipment & Supplies
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Belkin G wireless Router
Do you have an all-in-one router from Comcast? For example, do you have the cable (RF) line and your PC plugged into the Comcast router? If so, unplug your PC from the Comcast router and connect the Internet port of the Belkin to the ethernet port on the Comcast router. Then plug your PC into the LAN port on your Belkin.
[PC] ---> [Belkin] ---> [Comcast] ---> Internet
Once you have connected your boxes as displayed above, you will need to power everything off and bring up the boxes in the following order:
Comcast (wait 60 seconds)
Belkin (wait 60 seconds)
PC
If you cannot get out to the internet, momentarily press the reset button on the back of the Comcast box. Comcast routers are weird. A poweroff should reset the router but I have seen a few times where nothing works until the reset button is pressed (this is also recommended by Comcast).
I hope this helps.
Dave Grannas
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
I am getting a connect to belkin54g mesg. when I have comcast service. Why?
This is a message from your router and not from comcast service.
Sep 25, 2008 | Computers & Internet
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting...
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
Jul 09, 2008 | Belkin Computers & Internet
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Hook up wireless interenet
Did you by any chance give you router the mac address on the wireless card? Do you have the comcast version of a netgear wireless router? Any wireless router will do also. Does not have to be netgear or from comcast. You can get online by the network cable right?. Where else are you trying to connect to wirelessly?
Let me know
comier957
Mar 27, 2008 | Averatec 3150H Notebook
Ps3
Are you going to connect your PS3 wired to your router or wireless?
1. check first if ps3 is working behind rca modem.
2. then connect a pc directly to your linksys router
3. open configuration page of linksys by typing your gateway on your browser. (usually it is by default 192.168.1.1)
4. go to applications and gaming tab
5. you'll find there port forwarding..key in your number there
> i guess your numbers are like 88 and 3764 (something like that)
6. if your trying to connect your playstation wirelessly, you need to know your wireless security (if your router is secured).
> go to wireless tab and look for wireless security
> get your key
7. go back to playstation and try to view your wireless network
> connect and type in your key
Jan 25, 2008 | Linksys Wireless-G WRT54G Router
2wire (1000-400108-001) Router Logo
411 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
