Question about Compaq Presario M2000 Notebook
My computer is hing
My computer is slow . can you do something ?
  • aswin_s May 11, 2010
    Can i upgrade my RAM to a higher model.... Iam currently using Compaq Presario M2271TU with a clock speed of 1.4GHz
    Master:
  • 538 Answers
Sure..do a clean and defrag..
Posted on Oct 17, 2008
  • 52 Answers
Better upgrade your RAM to 1GB or higher
Bemis whisper close toilet seat stopped being quiet, lid slams
This is probably a friction hinge. The slow closing feature is a result of friction within the hinge. So it sounds like the hinge has worn to the point of the friction being reduced. Another possibility is that some kind of lubricating fluid entered the hinge. If so, perhaps it will regain friction with time. Most likely the seat needs to be replaced.
Sep 02, 2017 | Bemis Home
Scvs605a slow cooker hinged lid replacement
Great news !
Think I found a place for you in Canada that carries the hinged lid for your model
it's $15.99
http://www.crock-pot.ca/en_CA/parts/crock-pot-slow-cooker-hinge-lid/7921000031743.html
happy cooking
Dec 05, 2017 | Rival SCVS605A Slow Cooker
Rear cover hinge for model scvs601-b
You can order new lid w/ hinge for $15 from manufacturer (http://www.crock-pot.com/customerservice.aspx) or I have been told they'll send it for free if you contact them (https://secure.crock-pot.com/contactus.aspx) and say the hinge broke. Might depend how old your unit is.
Mar 06, 2011 | Rival SCVI600BS 602Quart Slow Cooker
The hinge on the lid to my black oval crockpot broke off; the whole thing has been rendered basically useless
The lid hinge is only a convenience thing. Most crock pots don't have hinges. So, unless the hinge affects the functioning of the pot, It is really not rendered useless. If you don't want to buy a new one or can't find a replacement hinge then simply clean up the break so it doesn't interfere with place the cover on. Good luck
Aug 21, 2009 | Crock Pots & Slow Cookers
Printer top stuck in open position
Don't know if I can, BUT here's try ... jiggle the cover and see if you can slip things back. It's possible you got it too far out of alignment and it won't go back. Try something of that nature. Maybe you were too enthusiastic when you opened it. Also check to make sure there's nothing in the way, or something wrong someplace else. What does your computer say? Any message.
I have a Canon, but it's fairly new and if yours has a hinge on it that slips back, make sure your cover is high enough with your left hand so that the hinge inside the printer swings freely and slip your right hand back against the hinge and gently push. Try that. I have a PixmaM320 or something similar to that number.
I'm trying to get an old HPDeskjet1120c to print. So far, no suggestions on line or manufacturer's suggestions have worked. Steady print light, reset light off, and cartridge (bottom light) light blinks. Oh well Hope the above suggestions work for you.
Apr 25, 2009 | Canon Office Equipment & Supplies
Broken hinge on Portable Slow cooker
If you have your receipt and its less than 1 yr old, you can call RIval Products at 800-323-9519 and ask for the number to fax your receipt and they will send you a replacement.
But if its over 1yr old you can call and tell them how old your crock pot is and they "MIGHT" have you cut the cord and mail it in and send you another. If it wasn't used very much and they say there is nothing they can do about it, ask for a supervisor. And voice your disappointment in that model.
If nothing else, they might be able to guide you to purchase another hinge.
Hope this helps you and others!
Carol
Dryden Michigan
Feb 26, 2009 | Rival 38651-C 6-Quart
My slow close toilet seat squeeks when closing. Any suggestions?
If the hinge is plastic spray silicone lub on it,down into the hinge.
If it ias brass, put light weight oil like( 3in1) down into the hinge.
Wipe off excess
Jan 20, 2009 | Toto Aquia II Dual Flush Toilet
The water in the door comes out real slow
it souned like the resevour is getting to cold and freezing up and or where the watrer line goes thru the bottom of the freezer door hinge it may be kinked and not letting water flow thru.
Dec 22, 2008 | Whirlpool ED2FHGX Side by Side...
How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Pin missing from Lid hinge
Try taking the other pin out as a sample and taking it to your local hardware store. They usually have a huge array of roll pins, screws, nails, etc., and probably someone in the store can help you match up something that would probably work well enough to secure the hinge and make it useful again. Also if there is a variety of items at the hardware that would work, try to chose the one that is made of stainless steel so that it won't rust or corrode. Additionally, if this solution works, the small piece would definitely be much less expensive than buying a brand-specific small replacement part.
Nov 21, 2008 | Rival 38601 Smart Pot 6-Quart
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
