Question about Bernina Virtuosa 150
Bernina needle not working
I am trying to sew a straight line, my machine is on and there is power , but when I push on the pedal there is noise but my needle does not go down.
  • 202 Answers
Your bobbin winder is probably on. Flip it off.
Posted on Nov 05, 2008
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
How do I change the needle position on my Bernina 1630?
Not sure, but if this is the one with the track ball, try pushing in on it to activate needle position.
Nov 18, 2014 | Sewing Machines
Bernina sewing machine
Hook don't catch thread
Possible reasons:
  • bent needle
  • needle/thread combination is not correct. When sewing, the thread should travel smoothly down the long groove on the front of the needle. (see user manual, chapter "Threads and needles")
  • stitch plate damaged
  • wrong hook timing (sewing machine needs to be taken to a BERNINA dealer for servicing)
Aug 12, 2014 | Sewing Machines
My Bernina 1130 has zig zag problems. I have to turn my machine on for 10 minutes before it will even sew. When I sew straight it will skip a few stitches every inch or so. Now it will not zig zag mo
here are some suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
I really recommend having the sewing machine checked to
see if there is a internal problem, since you have to wait 10 minutes
before sewing & the problem with the zig zag & looping.
Oct 07, 2012 | Bernina Sewing Machines
My sewing machine won't sew
have you checked the needle to see if it's damaged,,if not sure replace the needle--flat side to the back side of the machine--all the way up into the needle holder
is it possible that you wound a bobbin & the bobbin winder spindle was not returned to the left position
Feb 28, 2012 | Bernina Activa 130
Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Dec 30, 2007 | Bernina Activa 130
Sewing Machines Logo
89 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
