I need help setting up wi fi
Just open your tablet's wifi function, at the same time, open your home's wireless network, then use tablet to search for home wireless, and get connected if it's found.
Android 4.0 Tablet PC
Ok! This is what I found out personally. The Wi-Fi connection needs to be a non-hot Wi-Fi network. Meaning certain Wi-Fi connections has a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best way to connect your Literati is to find a friend who has a Wi-Fi router and ask him/her of their password temporarily.
Now you need to enable the Wi-Fi under the settings area by hitting the menu button and scroll down to the settings tab. select the Wi-Fi or wireless option. Enable the Wi-Fi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless you know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software.
Now! The software version you need to have is version 1.9 or greater. After you upload the software patches which should take two or 3 times (Including restarts & power offs).
After this point you will need to set up an account thru the KOBO website ether using your PC or the Literati under the store tab. Once your setup with an email account it should display itself under the overview area on your literati under settings. From here it all downhill...
The Hopeless Literati Guru
What exactly are you trying to set up? Are you installing a wireless router?
