Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips magnavox Rear Projection TV 7P6033W101-Dead
I just aquired a PhillipsMagnavox RPTV from a friend. He said while he was watching tv he heard a pop and the tv went black. There's no picture, no sound, nothing. I plugged it in and pushed the power button. The green power light flashed on and back off and a click ocurred inside which sounded like possibly a relay switch or something. There is a second light beside the power light which I think is a stand-by power light. This light does not turn on when plugged in. I was thinking that it might be some sort of problem with the power supply board. Of course, I'm absolutely not an expert. Any help you can offer will be greatly appreciated.
Thank You,
Joe O.
Kansas
  • Philips Master
  • 5,568 Answers
The clicking you hear is a relay that repeatedly connects, then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 31, 2008
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Big screen problem
http://servicemanuals.vstore.ca/index.php/cName/phillipsmagnavox-tv-parts
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
