I have a television that only has a coax in jack. Also, I have comcast cable with a motorola dct2524/1612. How do I connect a wii to the rca jacks at the back of the motorola cable box and play the wii?
  • bob0range Oct 17, 2008
    Thanks I'll give it a shot
  • 905 Answers
You will have to use a vcr to take in the coax cable and the rca jacks and use the vcr or stereo reciever with a/v in and out and use that to switch between the cable and the game
Posted on Oct 17, 2008
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
Trying to hook up "back-up camera" which only has a coax output jack. Can I hook it directly into "ANT" jack or do I have to go through a demodulator and reduce to an RCA and then plug into V1 jack?
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Nov 25, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Coax Cable
You need a cable box if you have channels that are digital (mustly the channels above 74). If you do not have those higher channels you can use a vcr or a dved player that has a tuner in it. Put the cable into the vcr and then use the Video and Audio jacks (A/V jacks) and the back of the vcr that say "OUTPUT" and hook them up to the same type of jacks on the back of the tv that say "INPUT".
Nov 10, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
