Question about Olevia LT42HVi 42 in. LCD Television
No audio we got a new dvd and slipped it into our player and changed our "source" until the picture came on, just like always. But can't get the sound on the television to work. This has happened to us before and I thought there was something real easy we did to correct - but we can't remember what we did. so now we are sitting here w/a movie we want to watch and no volume on it.
  • Debbie Finch Sikes
    Debbie Finch Sikes Oct 17, 2008
    Well - the volume works when we are on "tuner" and actually watching the tv so I don't think it is the audio amplifier. Somehow we are failing to do some little thing and t hat's what is annoying.  the sound works for television and not for the dvd player. and yes, hubbie checked all the cords etc; and everything is as t should be.
  • 905 Answers
Do you have the audio cables plugged in the tv set?
Posted on Oct 17, 2008
  • 2 more comments
  • jason Oct 17, 2008
    I'm sorry for that you have a dvd on the tv, ok then you will need to unplug the tv set if you already checked the audio settings in the menu
    And if it still don't work for the tv inputs or anything the audio amplifier inside probably needs replacing
    is this dvd seperate from the tv? seperate the audio connection
    pull the power from the wall for a little while. or the input transistor is bad
    if it is an internal dvd? unplug the tv for a little while
    also try another dvd
    if that don't work the audio settings are not working for the dvd or the dvd player is not sending the audio out to the amplifier. unplug shood reset if not dvd player will have to be replaced
    also if you don't change the rating I can't help anymore
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
No sound when disc is in DVD player. Only picture.
The sound board is out in the dvd player. Try another source, such as cable, and/or a gaming system if the tv gets sound it is for sure the sound board on the dvd player. Always check to make sure the dvd player doesn't have a mute option.
May 07, 2010 | Philips MDV460
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
Tosheba 50hx81 no picture or sound. press on button and hear speakers do something but no sound
It is likely that you don't have the right input to the television.
First get a source that you know works. How about a DVD player.
Get the cables from your DVD player (should be yellow RCA or "Phono" plug for the composite video out put.) Connect only the yellow video out put to your t.v. input and then press the av input button until you see the picture (note: besure that the DVD player is turned on and you have a dvd in it. We sometimes miss the very basics).
Once you get the picture than connect the audio cables, should be red and white to the corresponding colors. Do you have audio now?
If this test worked fine, it is likely that the solution to your other problem is that you have it on the wrong av input and need to press that button a few more times to find your satallite or cable input. There is a possibility that you are trying to use the tuner in your T.V. and it may be again as simple as choosing antenna input and that too needs to be hooked up to a good source.
Write me back if none of this helped.
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
No picture
Lately I cannot get a picture when I turn on the DVD operation--the TV screen, as always, is on INPUT (Extension).....the unit show PLAY, but the picture does not appear--and the TV screen stays blue! The audio is on, but no video....
This is something rather recent. However, if I unplug the electric-power source for the DVD-player, then sometimes the picture does appear, though not always.
I have checked the manual but find no good answer there. Please let me know what to do....many thanks.
Aug 06, 2008 | GoVideo DV2150 DVD Player/VCR
No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
May 16, 2008 | Yamaha HTR-6080
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Nov 11, 2007 | Insignia IS-PDVD10 Portable DVD Player
Olevia LT42HVi 42 in. LCD Television Logo
119 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
