Question about Alpine Car Audio & Video
My alpine cda-7892 radio works and when i put in a CD it plays but no sounds comes out no matter how loud i turn the knob and then when i switch back to radio there is no sound either... how do i fix this? What buttons do i need to press?
  • soundaddix May 11, 2010
    do you have to reset the radio for it to come back on?
Check you settings as you can mute or turn off your internal speakers or Pre amp. I had the same problem and almost
http://akamaipix.crutchfield.com/Manuals/500/500CDA7894.PDF
Page 15
Posted on Feb 21, 2009
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
I put this in my car and the radio works but it dosent play the cds but it reads it
are you running the speakers through an amplifier? if so, it sounds like you are using the blue wire which is the antenna remote to turn the amp on. instead use the blue/white wire.
Nov 03, 2010 | Alpine CDA-7892 CD Player
I have a Alpine CDA 7892 CD head unit I just installed and the radio works perfect but when I play a cd it sounds very muffled and I can hear bass only. Is the unit bad?
If the sound is coming out clearly with the radio on, then there is a problem with the cd drive or its connections. If your stereo has aux. inputs, you could run an mp3 player until your ready to replace it.
Apr 12, 2010 | Alpine CDA-7998 CD Player
Need wiring diagram for cda-7892
Hi and welcome to FixYa.
Below is the wiring diagram for an Alpine CDA-7892.
It was captured from the user's manual available here.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Alpine CDA-7892 CD Player
On my Alpine CDA 7892 i have the aux cables right for my iPod but i don't know how to swith it to the "aux" , just CD or Radio, How do you switch it to the "aux" imput in the back
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Mar 28, 2009 | Alpine CDA-7892 CD Player
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
I bought a 2002 alpine cda-7892 cd radio i need wiring manual
just run the rca wires from the back of your radio to your amp as well run a direct power wire from your battery to your amp then run a ground wire somewhere on your cars metal surface look for a bolt that you can loosen to whrap the wire around then run a wire from your fuse box tap into a fuse socket that is only powered when the ignition is on you can buy a complete amp wireing kit at pepboys or walmart that will come with instructions good luck....
Jan 03, 2009 | Alpine CDA-7892 CD Player
Alpine cda 7892 cd output
Hve you checked the mute button??? if so then it needs to see a pro as this is a great unit so it should be serviced only by a great tech. I simply love the alpine seris!!!!!great choice in car audio man!
Apr 02, 2006 | Alpine CDA-7892 CD Player
Alpine cda-7892 Head unit overheating
Certainly, the output IC might need to be replaced, also check to see if there is a factory amp somewhere in the car. Additionally, double-checking the wiring is a must. How long does it take for the unit to heat up?
Mar 28, 2006 | Alpine CDA-7892 CD Player
Car Audio & Video Logo
142 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
