Question about Casio FX-7400G Plus Calculator
Is there any way to do matrices on a Casio fx-7400G PLUS calculator?
I have already looked this up, someone said to set up a matrix like this- [[-2,3][1,0]] and then put an arrow after that and go to options, calc, and choose mat, for matrix. I tried that and it says simp, not mat.... and it didn't work. Is there a way to input matrix?
  • Anonymous Mar 11, 2009
    same
SOURCE: ERR:SINGULAR MAT when finding inverse of matrices
If a matrix has a determinant of 0, this error appears. If you get this error, your matrix doesn't have an inverse.
Posted on Jun 06, 2009
  • 7993 Answers
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
  • 7993 Answers
SOURCE: How can I solve a matrix on my Casio fx-9750GA
If you have mastered matrix manipulations on the TI calculators, it should be a breeze to learn the same on the Casios.
A. Define the matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). exemple. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Exemple : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [* ) (MAT) [ALPHA] B [EXE]
Hope it helps.
Thank you for using FixYa.
Posted on Nov 23, 2009
  • 7993 Answers
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Posted on Dec 03, 2009
  • 7993 Answers
SOURCE: CASIO Power graphic /fs 7400G PLUS - how do I
Turn a calculator ON. If you see no icons, press [MENU]. Use the arrows to move the focus on the icon MEM and press [EXE]. Agree to reset all memory. If you need further instructions download the manual from the Casio website.
Hope it helps.
Thank you for using FixYa and for rating (NOT BERATING) this solution.
Calculate the inverse of a 4X4 matrix on fx-570ms
The Casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
The Casio FX115 ES handles matrices for up to 3X3 dimension. Create the matrix.Have its name displayed on the command line and press the [x^-1] (reciprocal ) key.
Apr 16, 2014 | Casio FX-115ES Scientific Calculator
Matrix casio fx9750giihow can I find eigenvalues and eiginvectors for a matrix in my calculator? :)
This calculator cannot find eigenvalues and eigenvectors of matrices for you. The calculator does have many row and column operation that you can use to solve your problem. You need to know the theory of matrices, determinants, and some eigenvalue and eigenvector finding algorithms.
Dec 13, 2013 | Office Equipment & Supplies
Want to calculate the inverse of a 4X4 matrix on a casio 991es
Sorry, this calculator can handle matrices with dimensions ranging from 1X1 up to 3X3 . To deal with 4X4 matices you need a graphing calculator such as the CASIO FX-9570G Plus, the Ti83Plus.
Oct 23, 2011 | Casio FX-115ES Scientific Calculator
How to calculate the standard deviation? casio power graphic fx-7400G Plus
Here are the capabilities of the Casio calculators.
The screen captures may not look like ones taken from the FX-7400G
plus display but the instructions are accurate.
In stat enter the values in List1 and the frequencies in List2 (if doing paired variable statistics)
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-variable stats or regressions.
Use you knowledge of sample standard deviations and
population standard deviation to select which is relevant to your case.
They are given by xsigma-n and xSigma n-1
Aug 15, 2011 | Casio FX-7400G Plus Calculator
How to do matrix multiplication in scientifically calculator
Here is an account of what you can do with matrices on this scientific calculator. Certain precautions must be taken as concerns the dimensions of the matrices. Refer to your text book on matrix algebra.
On this calculator the largest matrices you can define have dimensions 3X3.
  1. First you must set Matrix calculation: Press [MODE][6:Matrix].
  2. Then by entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix (mxn].
  3. Once finished entering the matrix you clear the screen.
  4. The operations on A SINGLE matrix are available by pressing [Shift][Matrix].
  5. The choices are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:MatB] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
If you have defined two similar matrices (same number of row and same number of columns) you can ADD them or subtract them. The operation keys are Plus and Minus as for any number.
To multiply you use the multiplication sign. The matrices must be compatible (mxn) multiplied by (nxk).
Aug 10, 2011 | Casio FX-115ES Scientific Calculator
On which calculator can i solve 6*6 matrix
If you want to manipulate 6x6 matrices, you can use one of the CASIO Graphing calculators, such as theCFX-9850GPlus, or the FX-9750G plus.
Graphing calculators from other manufacturers can also handle such matrices. The FX-115ES can handle matrices with dimensions up to 3x3.
Nov 25, 2010 | Casio FX-115ES Scientific Calculator
How do i do a matrix problem in my casio fx 115 es, i don't get to work manual instruccions with my book problems
Hello
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[4:Matb] access Matrix B
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match (see you textbook for the rules)
Read the appendix to your user manual, there are several exemples.
Hope helps
Oct 11, 2009 | Casio FX-115ES Scientific Calculator
How to do matrix multiplication on Casio 115ES?
Hello
Hope helps
Sep 10, 2009 | Casio FX-115ES Scientific Calculator
How i solve 12*12 matrix using this
Sorry to be the carrier of bad news. The calculator FX-7400 G cannot perform matrix calculatioms. Use a Fx-9750G or other calculators.
Aug 14, 2009 | Casio FX-7400G Plus Calculator
Casio FX-7400G Plus Calculator Logo
716 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
