Question about HP iPAQ H1945 Pocket PC
Hp ipaq 1945 wont stay on, wont charge
I just bought one used from a co worker, who didn't disclose any problems, but I will plug it into the charger, the power light will flash twice, and then nothing happens. I can power it on, but only briefly before it shuts off. If I power it on and then plug it in, it appears to go in "standby" mode with the screen getting dark and you can't do anything with it. I've tried two different connectors for the power, could it be the battery? Or a problem with the charging point?
4 Suggested Answers
Stone3333
  • 19 Answers
SOURCE: Ipaq h5555
I battery dead ? In some case, ipaq battery dead will not start. ================
Posted on Aug 07, 2007
rolltape
  • 58 Answers
SOURCE: Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Posted on Feb 05, 2008
Bogdan
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
Internal battery charger
Yes you can buy them on e-bay here is the link for one
http://www.ebay.com.au/itm/Charger-For-HP-iPAQ-hx2100-hx2400-hx2490-hx2750-364401-001-367205-001-/360527673086?pt=AU_MobilePhoneAccessories&hash=item53f11fb6fe just charge up the battery externally and away you go I bought a second battery so I can have one on charge charging while I am using the one in the IPAQ so no down time
Dec 08, 2013 | HP iPAQ HX2490 Pocket PC
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
My hp ipaq 111 doesn't charge when I use an USB cord and adapter. I got it in Feb 2010. I replaced the battery to see if that was the problem. Still, when I plug it in nothing happens unless I do a soft...
Are you using the factory adaptor to charge the device? The reason I ask is that some aftermarket chargers don't have the required amperage output on the USB port to charge some devices. If you are using an aftermarket charger, try purchasing one from HP directly or look for a charger with a USB port power rating of 4-5 amp. They can be purchased on eBay or Amazon for around $10.
Jan 27, 2018 | HP iPAQ 111 Classic Pocket PC
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I just bought a battery charger, plugged it in and its not charging
I suggest to you to buy a new battery for you HP iPAQ H4150 Pocket PC and see if that charger will charge it up. If the new battery does charge then the problem was with the old battery.
If it doesn't charge up on the new battery then, your problem lies with the battery charger. You should check that the voltage of the battery charger is compatible to charge the voltage of the battery.
Hope I have been of assistance to you,
Cheers :)
Apr 24, 2010 | HP iPAQ H4150 Pocket PC
I need a charger for my hp ipaq but i don't know what series
In general, there's three types of charger you might need. Really ancient iPAqs used a round DC jack type charger, then there was a long time where all iPaqs used the same flat 22-pin connector. More recently, HP has moved to the same mini-USB plug used for a lot of mobile devices.
If you're really stuck, try http://www.ipaqrepair.co.uk/store.php?cat_id=25 and match your iPaq to the pictures.
Jan 12, 2010 | HP iPAQ 612C Smartphone
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Sep 23, 2009 | Compaq iPAQ H3630 Pocket PC
Unwanted soft reboot
Thanks everyone for looking at this problem, but I think I have fixed it. I had purchased an after market battery pack for the h5455 and the pins were not aligning up properly. The pda was coming on, but when it got banged around a little it must have caused it to reboot. I just bought a HP battery pack and all is well. Thanks again.
Bobc2
Feb 29, 2008 | HP iPAQ H5455 Pocket PC
IPAQ hx 2110
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
Dec 22, 2007 | HP iPAQ HX2110 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H1945 Pocket PC Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
