Question about Toshiba Satellite A135-S4527 Notebook
Can i clean my screen from the inside
Theres a big v on my computer screen that looks like black and green ink can i take off the screen and clean it from the inside if not can i fix it without having to take it to a technician
  • 905 Answers
If you have a v looking line then the screen could be cracked ! you cannot clean the inside of those lcd's
Posted on Oct 17, 2008
Doesn't turn on, green ink
clean the green ink inside, check the ink cartridge and if possible change it
Nov 29, 2009 | HP DeskJet 3550 InkJet Printer
HP 3180 BLACK IS PRINTING LIGHT
Call HP.
There is an un-acknowledged issue with these printers having problems like that ....
They end up replacing some big parts inside it.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Too much green
Printing too green is a sign of low or no Magenta ink. Might pay to look there. (Green is Cyan and Yellow ink, so Magenta is missing to make Grey/Black)
Sounds like someone might have also managed to mix up an ink cartridge and put it in the wrong slot?
Check that the nozzle patterns for each colour are in the right place on the print out according to the sample in the manual / online. Maybe Magenta is missing altogether?
Apr 21, 2009 | Canon i860 InkJet Photo Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Nov 18, 2008 | Dell 924 All-in-One InkJet Printer
Big Black Ink Line in all copies
Lift up a lid and clean the tiny scanner glass. One black dot will cause that effect to happen when using the document feeder. If the glass is clean, open the door on the right side and look at the green drum for lines. If you see any lines on the drum, then it's time for it to be replaced.
Sep 22, 2008 | Sharp AL 1631 Copier
Black Ink won't work
Here is what I did and it worked: I took an old cartridge, cleaned it out and filled it with computer cleaning solution (denatured alcohol?) that I bought at a big box store... when I did the clean cycle 8 times, the black finally came out... messy at first, with obvious particles. After 4 copies in black, the printer was fine. This is a pretty common problem, and the guy at the shop that is their first thing to do on pretty much every printer they see like this.... they buy cartridges loaded with solution for just this problem.... the rest of us suffer.
Jul 02, 2008 | Brother MultiFunction Center MFC-440CN...
Tv turns on but no picture, just black screen and no sound. older big screen 57"
There are some fuses inside the set. If you are technically minded, look for one glass fuse and several fuses that look like resistors, but are a green color. Otherwise, I would say you could be looking at a few to several hundred dollars of repair cost by a technician. If you need to have someone look at it, I suggest looking at this website to see if there is a local repair person in your area.
May 07, 2008 | Televison & Video
Color Quality is not so great anymore
Sounds like the machine needs to be cleaned. Probably a heavy use machine that has quite a bit of ink spray build up on the inside. I would imagine your service station has quite a bit of ink build up in it as well possibly causing the cartridges not to be cleaned like they should. A good cleaning cures most of what ails inkjet printers. We would charge $85 in our shop for complete disassembly down to the metal frame and cleaning.
Inkworks
May 05, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Screen cracked
buy one on ebay that has other problems not screen and replace it
Dec 05, 2007 | Insignia NS-DV2G MP3 Player
Toshiba Satellite A135-S4527 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
