Question about Pioneer Televison & Video
Pioneer plasma pdp4214hd shuts off after being on for about 20 min.
    Scholar:
  • 86 Answers
Are you able to turn the TV back on immediately or do you have to wait? If the TV is consistently shutting off around 20 minutes, this may indicate an overheating issue. It is possible that you need to clean the TV out of dust or it may mean your cooling fan is dead or not revving up when the temperature rises. If you are not able to turn the TV back on right after it shuts off, overheating is likely the issue, as you would be forced to wait until it cools down. If you are able to turn it back on, for how long? Does it continue to shut off after another 20 minutes? It is possible that the thermal sensor on the mainboard is defective, or that the software that controls the sensor maybe corrupt. Service or a firmware update may resolve this. You would have to contact the manufacturer.
Posted on Oct 17, 2008
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Problem with Pioneer PDP-5080HD 50 in. plasma television The power turns off every 15-20 minutes
hi,
There is some over heating problem in you television. there will be two fans inside you television. if any of the fan get faulty then that section of you TV will get over heated and will shut off by itself preventing from further damages. Check the two fans. For that you have to open your TV.
ok
Jun 07, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
My plasma turns itself off for about 10 20 mins
It seems that your unit has some sort of Thermal PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. After it shuts down and the faulty component(s) cool down, it restarts again until it once again goes critical and shuts down again only to repeat the cyle.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a pioneer plasma tv about 2 yrs old.It goes to standby mode every 30-40 min.Even when shut off it will return to stdby???Thanks
check batteries on ur remote even hide it in other room/if not it could be power supply over heats it
will shut down/another thing go to menu reset to factory default.
Jan 05, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Shuts off automatically after 20 min pioneer plasma 5080
sleep timer may be turned on ,turn it off in the TV's setup menu
Sep 19, 2009 | Pioneer PDP-5080HD 50 in. Plasma HDTV
One side of my tv heats up on my pioneer pdp4214hd
Because this is a Plasma flat panel there are fans in the back of the unit that will keep things cool. It sounds like there may be a fan that is not working on the left side. I know that my plasma runs very warm, around 98 degrees F. The power supply is also on the side that you are talking about. Since the set is still working, I would not suspect any other problems, but, I would not run it very much until the unit is repaired.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 15, 2009 | Pioneer Televison & Video
Remote control dosnt work on this tv
I have the same plasma Pioneer tv. I also tried a replacement remote and no fix. I replaced the infrared receiver module (~$4 from Radio Shack) on the TV, yes it involved taking the tv apart. Voila, now I have two working remotes.
May 12, 2009 | Pioneer Televison & Video
My 60''pioneer plasma blinks 12 times after i turn it on
looks like 12 blue blinks is a communication with the Digital tuner error. pioneer had a software upgrade/fix for this in some cases, others might need a new digital tuner pcb. I would unplug all power, wait 5 min, plug in (wait1 min) and try it again. If it is software, it should hopefully work. Make sure you pull your cable card if you have one. If it still won't turn on, you probably need the digital tuner board = $200-500 repair. Pioneer is usually very helpful, I'm really surprised they didn't help at all.. They'll want model #, serial # and date of purchase.
Jan 31, 2009 | Pioneer PDP-6070HD 60 in. Plasma...
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Televison & Video Logo
178 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
