TV WAS DROPPED AND NOW ONLY THE TOP PORTION OF THE SCREEN IS VISIBLE. THE REST OF THE SCREEN IS BLACK AND MULTI COLORED
    Scholar:
  • 86 Answers
More than likely the light engine was knocked off alignment, or is now defective. To verify this, if you bring up the TV's onscreen menu, is it only visible on the top portion? If not, and it looks normal, the problem will be with the input board as it is not able to properly send the whole signal to the processor. The onscreen menu is a signal also being fed through the light engine so if it looks fine, the light engine, which is very expensive, should be fine as well.
Posted on Oct 17, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Colored lines appearing from bottom to top of the screen.
the LCD is a very complicating device for all CP. you may check it by disassemble it to it's LCD and connect the ribbon wire/flex of the LCD firmly... but this problem is best to replace it with a new LCD... very complicated device indeed
Jun 03, 2010 | Sony Ericsson w580i Cellular Phone
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Only approx. 4'' of visible screen rest of screen gray
adjust your screen resolution until it fits as you have the resolution higher than the native reolution of you monitor
Mar 30, 2009 | Computers & Internet
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
