Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Leaks near filter
My Equator EZ 3600 CEE leaks a lot as the washer drains and when the condenser drains during the dry cycle. This leak seems to bypass the filter as I find nothing in the catch though I've run lots of loads.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
It may be the drain pump that is leaking, you can open the back panel of the unit and figure out if it is so by checking the drain pump for leakage just when the pump starts to work.
Posted on Feb 26, 2010
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
Sep 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
My equator ez3720 cee combo washer dryer doesnt dry well
Unfamiliar with these machines. The dryer portion probably works like any other condenser dryer so that means it has a condenser which is used to remove the water from the warmed air. If the condenser is clogged and in need of cleaning the drying mode will suffer. The lint filter should also be cleaned. Like I said I never even saw one up close.
Nov 04, 2011 | Equator EZ 3720 CEE
Leaking from drain hose
You need to change the drain hose with a new one.
Get a proper threaded hose to avoid the same
problem in the future.
Sep 02, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
Feb 27, 2009 | Equator EZ 3600 CEE Front Load Washer /...
A lot of water remains in machine at end of wash cycle
The drain pump might have gone bad, check if the drain pump is making some kind of noise and also check if the drain pump is not obstructed.
You can open the coin trap on he right hand side bottom of the unit and clean the same for any blockage.
Nov 27, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
195 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
