Just replaced my bulb. Need to reset timer. - Televison & Video
  • 86 Answers
This would be done in the TV's onscreen menu. Since every TV has a different OSD, my advice would be to Google the TV's model number along with User Manual as it would explain how. Most manufacturers provide an electronic manual for their products on their website, just find the model number from the back of the TV.
Posted on Oct 17, 2008
I have a Mitsubishi 60inch 60737 replaced the bulb last it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
Mar 03, 2011 | 3M X50 Multimedia Projector
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi HC 900 DLP Projection Lamp Shutdown.
Honestly I would try entering the 'Lamp timer reset' code again. Or the button sequence given to reset the lamp timer.
An issue that may be happening is that something may have happened to the lamp ballast power supply also.
Just a thought.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
