Power not getting thorugh. The projector was working a while ago. The power plug was pulled out accidentally when it was switched on.
  • sailajaavula Oct 17, 2008
    very useful. thanx:)
    Scholar:
  • 86 Answers
The only step you can try to resolve this is by doing a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. If this doesn't work, something spiked in the circuit board when the power was abruptly shut off. Circuit boards are very sensitive to this and service would likely be required. When you turn the TV on, is there any attempt by the TV to turn on? Are you hearing anything or seeing an LED flash? If no, the power supply's fuse may have blown or the power supply is now defective.
Posted on Oct 17, 2008
Color wheel replacement
good times here--take the front and rear bezels off and remove the top cover. remove the power input board and power supply. next remove the metal shield covering the bottom of the projector to expose the main board. next, cut the ribbbon cable as close as you can to the color wheel. remove the color wheel leaving the cut ribbon behind. Now, carefully set the new color wheel in the general area and tape the new cable to the cut cable. Next pull the cut cable out of the main board paying careful attention to which way the cable was plugged in. Now pull the new cable thru and remove the tape and the old cable, plug it in, install the new colorwheel and put your projector back together with the exception of the front and rear, turn it on and make sure the color wheel spins, if it kind of just jumps, it means you plugged the cable in backwards. also when you test to see if it works, make sure the lamp door is shut so the safety switch is pushed in, otherwise the projector won't light.
Apr 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
InFocus Won't turn off, no powering down, and no projection
The 4805 does not have a power button it has a power switch next to the mains power connector but that switch has no lights near it.
If you meant the power light on the top of the projector right next to the menu button is yellow that is bad. it indicates that the main board is not working which would explain the projector always being on. also the led being orange means that both the green and red led's are on at the same time (this is BAD)
This is not a valid function for the led's. Another indicator that the main board is wacked. By the way if you received the projector less than 30 days ago you can file a claim with the eBay resolution center that the projector is not as advertised/Described in the listing. And you might be surprised when you get your money back! the "NO RETURNS"is null and void if there was any gross misrepresentation or deception in the listing!! i.e. Not as described...
Sep 19, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Oct 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Oct 01, 2008 | Optoma EP739 Multimedia Projector
Boxlight cp-310t won't display image
loose connection. possible crack on main board. needs to be sent in to have a look at.
Aug 16, 2008 | Boxlight CP 310t Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Not powering up: Sony VPL sc24
TRY TO CHANGE THE CONVERGANCE IC
Oct 31, 2007 | Televison & Video
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
