Question about Kitchen Appliances - Others
1700 watt fog machine keep tripping GFC and blowing fog machine fuse
Just bought a 1700watt fog machine that keeps blowing the GFC in the garage when I turn the machine on. I tried then plugging it into a kitchen outlet and it blow the fuse in the fog machine. I replaced the fuse and tried the pluging it in to a outlet in the basement. This time it didn't blow but I didn't trying the fog machine in the house. Any ideas what the problem is? In the garage there is a 220 outlet with the weird plug? The manual of the fog machine is at http://64.233.169.104/search?q=cache:HEWjL9TQv5AJ:www.chauvetlighting.com/system/pdfs/f1700.pdf+Chauvet+F-1700+manual&hl=en&ct=clnk&cd=4&gl=us
Thanks
todd
    Scholar:
  • 61 Answers
The fog machine needs to be on a dedicated line because of the wattage it does and the amp is rated as a 15 means the circuit breaker on this line needs to be 15 min safe at 20....
the fog machine is like a mircrowave and any major appliance needs dedicated lines not shared with lights or outlets besause it draws a lot of power to start and run and depends how long watts is simular to power the more light bulbs connect to a circuit breaker adds up 4 75w light bulbs adds up to 300 watts and that not includling outlets that may be connected....
not a gfci Unless dedicated at 20a....
Posted on Oct 17, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
Low beam/High beam fuse keeps blowing
Have you changed the bulbs lately......
Turn on with your fan flat out and rear demister on, see if that makes a difference.
Have you got the correct fuses in?
Mar 12, 2014 | Mercury Cars & Trucks
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
The dash board lights are not working and the
hi mate if you keep blowing fuses disconnect your front fog lights and try again if your dash lights work then a bulb has failed and gone to earth if it still blows the fuse disconnect the dahs pod (clocks) and reconect the fog lights if it does not blow the fuse the it probably is the dash pod or something associated with the pod hope it helps
Apr 02, 2009 | 1994 Subaru Impreza
1992 acura integra tail light fuse keeps blowing
it sounds like the wiring is all wrong as if its a bad earth on the car after he wired the fog lights maybe you should check and see if there is any wires hanging down underneath the bonnet that have been stripped back or see if there is and loose wires on the back of your lights or fuse board if you dont find any problems there take out the radio in the car i find that most problems to do with bad wiring or electrical problems in cars is to do with bad wiring on a radio i.e not having been installed proberly. hopes this helps
Feb 19, 2009 | 1992 Honda Civic
Saeco Classico is tripping the GFC outlet
Your machine has a bad heating element and is ground out to the boiler ground. You will need to have the boiler rebuilt.
If you need service you can contact Cerini Coffee Services in New York. More information go to www.Cerinicoffee.com or go to saeco's website to find a local service center.
Hope this helps!
Johnny
Sep 20, 2007 | Saeco Classico Espresso Machine
Kitchen Appliances - Others Logo
443 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
