Question about D-Link DI 514 Wireless Router (DI-514)
D-link DI-514 i have a router DI-514 . I wanna install but i dont know how. i put 192.168.0.1 then appears a box asking for username and password some guy told me that i goota put admin as username and leave the empty space as password. but I did that and still it dosnt work. can u guys help me please ???
  • D-Link Master
  • 787 Answers
The information he gave you was correct for a new DI-514 but if this has already been used it could be that the password was set. To take care of this problem, you can return the router to factory default settings by inserting a paper clip into the reset hole at the back (leave the router plugged in and turned on), hold it for ten seconds and then release. The router should reboot. Try the 192 and admin again.
Posted on Oct 17, 2008
I want to insert a password in internet connection Braggion Giorgio
You should connect to router configuration page using your web browser. Normlly the adress you should type is 192.168.0.1. If is the first time you install it or it has factory defaults you will be asked a username and a password. Type admin as username and leave the password field blank.
Now you are in router configuration page. From here you can choose a password to protect your wireless lan and a password to protect router access.
For more info contact me or go to www.dlink.com
Mar 30, 2011 | D-Link DI 514 Wireless Router (DI-514)
I am not able to connect to the router from my laptop. D Link 514 Wireless router
My friend,
Please reset the router in that case and login into the router setup page.
This will ask you for a username and password which is Admin and password is password
1.Again select the wireless settings and network name.
2.Save the settings .
3.Restart the computer and router as well.
Regards:
Amit Awasthi
Dec 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do i get my internet conection "security-enabled"
First, to practice what you need to do, go to this site
That's the emulator provided by DLink for your router.
Alright, next step is to connect your PC to the router with an ethernet cable- by changing your router settings, you will lose wi-fi connection until you change the setup in your pc.
Now then, in a browser type in the address bar 192.168.0.1- you should get a box that asks for a username and password- default is "Admin" and nothing in the password box.
Click the wireless button on the left side-
Change WEP to "enabled", put in your phonenumber for the first key, then hit apply
You will need to rescan the network- Windows will prompt you for the password- enter it, should connect- and you're done
Sep 21, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I put a password on my existing router
Open your web browser and type 192.168.0.1 in the address bar to access the router's software. It will ask for a username and password. The factory sets are username: admin and leave the passowrd blank. From there you should be able to change your settings
Jun 25, 2010 | D-Link DI 514 Wireless Router (DI-514)
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
When i type in the router network ip address http://192.168.0.1 the box opens and i type in admin for username and leave the password blank it just clear's everything and ask for username and password...
Type "user" for the username instead of "admin" & leave the password blank. This should work.
Here is a link to a list of the D-Link default passwords:
http://www.default-password.info/d-link/
Oct 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Di-514
When you go to your routner and put in username and password, the boxes that are a "lot of stuff" has a tab on the top HOME being one of them, and a tab down the side WIRELESS being one of them. When you click on WIRELESS, you should see a screen that has a box marked Enabled or Disabled. Check ENABLED. Give your SSID a descriptive name like Eagleye and (optionally) turn on WEP. I tend to give all of mine 1011121314 as the 64 bit encryption so I never forget it.
Save your settings and your SSID name should show up on wireless devices. If it doesn't, then click on ADVANCED and PERFORMANCE tabs and make sure the SSID is enabled. Keep in mind that you can also DISABLE SSID and set up all your wireless devices by keying the SSID the same as the one you gave it. Then you don't have to use WEP and it will improve your wirless performance.
Here's a link to the 514 manual if you need to ask other questions. This is for a rev C, but you can step back into the website for an A or B model. Most notably, check out the WEP and SSID FAQ tabs.
http://support.dlink.com/products/view.asp?productid=DI%2D514%5FrevC
Carl
Oct 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI Liks DI-514
http://support.dlink.com/downloads/
Select: DI Select One: 514
This is all that is available for this router from D-Link.
http://support.dlink.com/faq/view.asp?prod_id=1513
This page probably can answer any question you have about configuring this router.
Lost my username and password
Reset the Router, and you will have to set everything up again. To avoid losing this in the Future, Put a Piece of masking tape under the router and Write your Information there. Not a Security threat as anyone that wants on your Network would need to be in your Home to get this information
Jul 12, 2008 | D-Link DI 514 Wireless Router (DI-514)
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
653 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
