Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Two issues Ice maker makes loud crashing sounds but makes almost no ice. I thought someone was breaking in once evening, it's that loud! The upper compartment freezes soda cans,it freezes just about everything even set at 40. The deli tray is OK it hasn't frozen food so far, sometimes the veggie crispers freeze also. Frig started out not cooling enough even when set at 34, that was 14 months ago. It freezes almost all the time now. Any ideas? This is a French door RF265AABP, purchased in July 07
  • 2 more comments
  • terie-v Oct 17, 2008
    Thank you. I would be nice not to have to buy ice, since it makes almost none. How about the food freezing? could it be connected to the noise and lack of ice??
  • terie-v Nov 11, 2008
    THANK YOU!!
  • jkurach Feb 23, 2009
    I have the same problem with a RF267AB, the ice was getting stuck in the ice maker. I called Samsung but they had no good info, they're supposed to call back, we'll see. I got the ice loose by shutting the freezer and regrigerator off for a couple of hours and letting the ice melt a bit. When I turned it back it was able to kick the stuck ice out and started making ice again. I'll try the solution of cleaning the contact.
  • Anonymous Apr 02, 2009
    Same issue - ice maker makes very little ice, maybe two or three glasses worth then you have to wait until the next day. Mine has stopped working 4 times (today again). I would not buy one of these units
  • 4 Answers
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Posted on Oct 31, 2008
  • nate2274 Nov 06, 2010
    I have the same problem. I disassembled, thanks for the details, but I can not locate anything that looks like a metal strip to clean.
  • alterna Jan 28, 2011
    Some info that helped me: the sensor contact is next to the ice cube molds against the plastic housing. Also, there is no water line attached. I was afraid to pull the ice maker as shown on the Samsung site and this guide because I didn't know how the water line was attached. Well, its not! One screw, one harness, one clip and presto - ready to troubleshoot or replace. Why doesn't Samsung tell you how easy it is to replace??? Thanks Elbozi.
  • 120 Answers
It could be a damper issue or control board i will take a look at the schamatics tomorrow at work on my laptop that i use for for work i will let you know if i find something use full
Posted on Oct 17, 2008
I have the same problem but when I took it apart the ice was filled to a proper level... just won't eject it. Is there some kind of coating on the tray? I ejected the ice by hand and it actually takes quite a bit of force to remove.
By the way, thanks for the pictures and description on how to get it apart.
Posted on May 15, 2010
Ckoonz, I had the same issue. It appears for me the heating element that allows the ice to be pushed out had failed. I new icemaker (<$100 from Samsung) fixed it for me.
Posted on May 21, 2010
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Rival icecream maker
Perhaps some gears are breaking inside the motor? If you need parts, they are sometimes available here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=rival+ice+cream&submit=Search&_sid=93311479
May 27, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
Very Loud Ice Maker in GE gfss6kkxs Fridge
Sorry to inform you but GE refrigerators are known for their noise making machines. I myself have a GE Profile side by side but will never own another GE product. After repairing appliances GE is better priced than their competition and the reason cheaper made product. Sometimes cheaper doesn't mean better. Outside looks really good but what you don't see is ugly. BB
Jan 20, 2010 | GE Refrigerators
My EdgeStar Portable Ice Maker stopped making ice
The ice bucket is probably cracked we have had three that have all done the exact same thing all different name brands. Just order a new ice bucket. Good Luck and my advice is to purchase a extended warranty on these because its not a matter of if it will break its when. Edgestar lasted the longest it lasted 1yr and 7months.
Aug 04, 2009 | EdgeStar Titanium Portable Ice Maker
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Samsung RF267AABP Noise problem
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Mar 06, 2009 | Samsung RM255LASH Side by Side...
Noisy ice maker
I too have the incredibly loud ice dumping going on in my 4door new Samsung refrigerator that echoes throughout the house and could wake up a neighbor!! All the above solutions appear to be from repairmen that are not giving any solutions to the VOLUME issue of the ice being dumped. I prefer not to spend
$300 for a visit to tell me that "that's just the way it is", you'll have to live with it. Call Samsung or write them and tell them
the ridiculously loud sound from the ice dropping in the tray is
unacceptable. I'm going to!!
Nov 18, 2008 | Samsung RF265AA Bottom Freezer French Door...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
3,788 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
