Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Delta Faucet Kitchen Single Pull
Faucet drips water. Can the internal washer be replaced.? How to?
  • Anonymous Mar 21, 2014
    I have a single handle pull-down kitchen faucet that I need parts for. The faucet has 413763 stamped above Masco on the front of the base. I cannot find any reference to this model on Delta's site (Masco owns Delta) or anywhere else.
    It has a single handle separate from the pull-down faucet and came with a soap dispenser. I bought it from Lowes about four years ago.
    Help? I really need parts or I'm going to have to replace the whole thing.
    Scholar:
  • 68 Answers
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Posted on Dec 09, 2008
My Delta 174--WF has a constant drip from the faucet. I'm not sure how to take it apart to fix it, or what parts to replace. Can you help?
Turn off water supply and use allen wrench to remove handle then remove bonnet nut then remove internal parts replacement kits available at most lowe's and other home improvement or hardware store or plumbing supply stores take care to document how everything is removed so you can reinstall exactly how it came out.
Jun 06, 2011 | Delta Faucet Delta 174-WF Waterfall Single...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
I have delta palo model kitchen faucet that has a
Delta faucets have a lifetime warranty. Call them and tell them, they will send you a rebuild kit. You can rebuild the whole faucet, it will work like new again.
May 02, 2010 | Delta 467-SD Palo Single Handle Kitchen...
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Leakes around spout
You remove the handle after turning the water off the to faucet. Remove the retaining nut which is apart of the trim. The ball assymbly will pull right out and you will find the two little washers and springs below the ball. You can buy a rebuild kit with the new ball if you like but it is not necessary. When you do replace the washers, it might be necessary to tighen the tension ring that is on the retaining nut. Tighten it unit it doesn't leak around the ball stem.
Apr 02, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
430 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
