Question about Konica Minolta DiMAGE 7 Digital Camera
Warning:Unable to use the card, so i can not take a photo!
Hi guys,
insert a fresh CF card, turn on the camera, a little red rectangle appears in the screen, and i can see three red "X" s.
Does anybody enconter this issue, please help me, thx!
  • 3 Answers
Try too format your CF card in FAT (not fat32) in a computer.
Posted on Jan 17, 2009
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
steps:
camera body.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Hi, all of a sudden, my Canon Rebet XT gave me a faint flashing error 99 message. It won't turn off and the red light at the bottom right of the screen stays on even when I turn my camera off. I have to...
To isolate the cause of the issue, we suggest that you do the following:
4.clean all lens contacts on lens and camera with a rubber eraser
5. Insert a fully charged battery, and turn on the camera.
6. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
>from :
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
May 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
camera body.
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Feb 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
camera body.
Jun 28, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
350D, focuses but won't take photo!
Does it do as you describe with a different lens? Have you ever had "error 99" or any other "error" show up in the upper LCD panel?
May 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Konica Minolta DiMAGE 7 Digital Camera Logo
112 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
