Question about RIM BlackBerry Curve 8310 Smartphone
Cannot Voice Dial from Bluetooth H700, Address book won't transfer
Bluetooth device Motorola H700 worked fine and was able to voice dial, then it stopped. Removed the bluetooth device and paired again. Bluetooth works fine if I dial from blackberry, but when I push the "talk" button on bluetooth, phone screen says "initializing, please wait" and never prompts for a command and screen never changes. When I tried to manually 'transfer address book, got error message: Unable to locate object push server.
Also, just started: Call log will not reflect any entries, although it is set for all.
  • 9 more comments
  • Anonymous Oct 27, 2008
    same problem
    I have the same problem.
  • jeneen351 Oct 29, 2008
    I have the same problem as well. Voice dial worked for about a month and then it'll just sit there initializing.
  • jmelanc Nov 05, 2008
    I have the same issue with my Motorola bluetooth H710 and the Blackberry Curve. It worked when I first paired it - less that two months ago, when I first got the phone. Now no voice dial on the bluetooth, and pretty slow on the phone itself.
  • imab5fan Dec 03, 2008
    Exactly the same symptoms. Someone please help.
  • Anonymous Jan 02, 2009
    I have the exact same problem. Worked great for a week, then will not initialize for voice command from Bluetooth
  • jobu369 Jan 13, 2009
    Same exact problem
  • Anonymous Jan 28, 2009
    Same exact problem. It is unbelievable that Blackberry doesn´t have any support for this !!!!!!!!!!
  • cmenusan Feb 13, 2009
    Same exact thing with my blackberry/bluetooth. Any solutions?
  • Anonymous Feb 25, 2009
    same exact problem has worked fine for a couple of months and then this just started.
  • ccgrouch May 02, 2009
    Worked fine for a while, now just sits at "Initializing; please wait..." I am using a BB Pearl 8120 with Motorola H700.
May not be the best one, but I just removed my battery and put it right back in and it works again.
Posted on Feb 13, 2009
  • Adam Levine Oct 20, 2010
    This was very helpful. More helpful than Verizon who said I should buy a new H700 from them at list price. Adam
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
HF850 pairs with my Ericsson TM506 phone, but can't voice dial
The TM506 (also known as Bella) must support the Bluetooth Handsfree 0.96 profiling.
The HF850 supports Bluetooth Headshet v1.1, v1.2 and Handsfree 0.96 protocol.
Unless you can find otherwise, the TM506 doesn't support Bluetooth 0.96 Profiles. It is my understanding that on the TM506 you must program your voice commands and I understand that to be different.
Nonetheless, the TM506 works very well and seamlessly (other than voice dialing) with the HF850.
Dec 24, 2008 | Motorola Mobility Bluetooth??¢ HF850 Car...
Adding voice to my phone book
press and hold the voice key, speak into the phone, release the voice key.
Oct 16, 2008 | Motorola Mobility RAZR V3
Will not voice activate
Does your Treo 700W support "voice dialing"? I searched the whole user guide for the Treo 700W and it does not say anything about dialing by voice. If the phone does not support it than no matter what Blue Tooth unit you use you will not be able to voice dial.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
Address book and voice dial
Menu / Phonebook for addresses. Menu / Tools / Dialing Services for voice dial.
Apr 21, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Voice Dial
I had a problem getting the voice dial to work on my K1 phone. The voice dial would not work if the contacts are stored on the sim, once they are copied to the phone memory all wored fine.
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
If you have the v3xx, it has speech recognition built in, you just press the voice dial key on the right side of the phone and say "name dial", then say the name of the address book entry you want to dial. The speech recognition matches up with your address book entries and repeats the name back to you. If you have multiple entries, it asks "which one". It's very cool and mine works very well. I was going through the same frustration you mention, looking for a way to add a "voice tag" to an address book entry like my old phone, but this is way cooler! Hope this is the fix for yours as well, good luck!
Dec 14, 2007 | Cell Phones
Voice commands
The telephone has this feature?
This feature is active?
As you sad it's appear that you use that in another telephone, try to check that.
Nov 20, 2007 | Motorola Mobility H700 Wireless Headset
Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
Jun 21, 2007 | Motorola Mobility H700 Wireless Headset
RIM BlackBerry Curve 8310 Smartphone Logo
630 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
