Question about Refrigerators
Shelf locators broken of the back the freezer on kelvinator impression series 500l
  • Anonymous Mar 19, 2014
    freezer cold fridge not
    Genius:
  • 1,239 Answers
Hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Posted on Oct 17, 2008
Kelvinator no frost
Please check if there is build up ice around evaporator fan.
Remove rear cover in the freezer and check defrost cycle
Aug 26, 2014 | Kelvinator Refrigerator Fridge Freezer...
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
I have a Kelvinator impressions series 390 fridge(no freezer) it keeps icing up and then thawing all over the floor. I have it set just left of "Mid". Can you help,it is driving me crazy!!!
There should be a drain tube that allows the freezer to drain into a pan under the freezer. Over time, the drain tube can become plugged with dust and food debris. Try clearing the tube and it may just take care of itself.
Feb 27, 2011 | Fisher and Paykel Refrigerators
Kelvinator 330 impression series fridge leaks water internally and runs on to bottom shelf. I cannot see where it is dripping from, the drain rack is clear as is the cooling component. This is a regular...
The drip tray is blocked, open your door, about half way down at the back you can see the drip try, on the Right hand side there is a hole where the water drains, poke a plastic straw down there to clear.
Feb 26, 2010 | Refrigerators
I have a Kelvinator 500L Twin Air No Frost and the freezer no longer freezes anything and the bottom of the fridge is just cold enough but won't respond to temperature adjustment. The motor runs 24/7 as...
I am pretty sure its the defrost timer not working so freezer coil is iced up preventing cool air circulation .you can call me on 0415867792 if you want to know more charles
Nov 11, 2009 | Refrigerators
I have a Kelvinator upright freezer (360 Impression series) that i bought 2nd hand and the thermostat runs constantly. Do I need to replace it? Can we DIY? How much is it likely to cost? Thanks if you can...
the clold cointrol wil cost around 50 dollars and theyt are not that hard to replace. take the model number and make to the parts house and they will be able to set you up with a new one. good luck
Jan 21, 2009 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
