Question about Kenmore Elite 45986 Front Load Washer
Kenmore f03 error message
I'm getting an f03 error on my kenmore front load washer. Can anyone help me with what this is. Thanks!
  • 63 Answers
Check motor if noisy or hard to turn its motor, also check concetions to&from ccu board and mcu board . "less soap plz"
Posted on Nov 15, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Getting an F35 error message on a front loading kenmore washer. Any suggestions?
This link should help:
http://www.managemylife.com/mmh/questions/123674-does-f35-error-code-indicate-kenmore-front-load-washers
May 20, 2011 | Kenmore Front Load Washer
Problem with spinning clothes
Hi
Error code F03 on Kenmore means that there is draining problem or a filling issue with the washer. Check if the washer is draining; also make sure that it is not kinked or clogged. If the drain hose is not kinked then next thing to check is Drain Pump. Check out this link to disassemble your washer---
Kenmore Washer disassembly
Now, check the drain pump for any blockages. Make sure that you have a container to collect water when you open drain hoses from the pump as it has a lot of water inside.
If the drain pump is fine then it is an issue with filling of washer. Check whether washer is filling and the pressure is fine. Also, make sure you check the softener dispenser. Pull the dispenser drawer out and clean it thoroughly. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. Please post back for any further assistance.
Daniel
Aug 02, 2010 | Kenmore 43142 Front Load Washer
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My front load Kenmore washer has a f03 code on the screen. It is not draining the water and it is not doing a max spin. What do you think I need to do?
F03 error code means that there is either fill problem, a drain problem or a water level pressure switch failure .
First ensure the machine is filling.
When the drain system is causing the F03 error do the following.
Ensure that the drain hose is not kinked or clogged.
If the drain hose is OK check the drain pump.
Start unplugging washer from main and remove the service panel at the bottom.
Follow the instructions on manual to remove panel.
Access the water pump and remove the hoses, clear any blockage in there.
Use a container to collect the water, be prepared. If machine has lot of water inside, remove some water with a sponge before undoing the pump.
Sep 27, 2009 | Kenmore 46462 Front Load Washer
I keep getting an H7 code on my machine and it stops and I have to keep restarting it. I need help.
Are you sure it is H7 - I don't have a listing for that error.
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine has a F03 code when it starts to rinse
Hi I would advise you to check the filters in the water valves and check them for being open circuit
Jul 18, 2008 | Kenmore 46462 Front Load Washer
Kenmore front load HE2 plus
I have a F01 error message on my Kenmore He2t washer. I tried to add clothes to a wash and restart and continue to get the message. Please help
Jun 14, 2008 | Kenmore 46462 Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
