Question about Dual Electronics CECT P168 Cellular Phone
P168 - shut down
My cell battery died, shut down normal , said it was powering down due to low battery. i fully charged the battery and cannot turn my phone back on! Help i have two batteries and neither one turns my phone on but they r both fully charged.
  • Anonymous Mar 02, 2009
    same as above
Try wiping off the connections n hold button down for a min.
Posted on Oct 20, 2008
The car was being driven and died. It turns over but wont start, and doesn't go into gear. Windows quite working and radio and clock don't come on. Buzzing sound from air bag mode.
Sounds like a power supply issue. Make sure the battery is fully charged and the charging system is working properly. If the ECM senses low battery voltage it will shut down different parts of the electrical system in order to maintain a constant power supply for the necessary electronics
Jun 30, 2015 | 1996 Mercury Grand Marquis
Computer will not turn on
If your computer is plugged into a power source, you may have to do a "hardboot" or reset ... if it has already shut down (for whatever reasons). Try pressing the Power (on/off) button down for a while (up to 15 seconds) ... or until you see it start up ... or, release and then press the power button again (normally) to see if it powers up.
If your computer is not plugged into a power source, it may have shut down due to low battery. And, until there is battery power, it will not start up (or wake up from sleep/hibernate mode). First charge the battery up (preferably fully), and then press the Power button to start up the computer.
May 20, 2014 | Samsung XE500C21-A04US 12.1" Chrome OS...
Check battery state
Same as a 12-volt cell, charge the battery fully first, then let sit a few hours.
Get a hydrometer from the nearest auto store, and measure the specific gravity of each cell (directions and measurements will be in the package). Each cell should read a value (for instance 1.20). If all are in the good range, then something else is going on. If one is low (for instance 1.0, while the rest are 1.2), try to run the battery down pretty low, then fully recharge it again, then retest. If same problem, that low cell is dying.
Not much you can really do about it though, once a cell starts failing the battery is pretty much done for. Although it'll be hidden some, because you have 24 cells averaging out to 48V, so a cell that should be "2.0" nominal, reading only 1.0V for instance, isn't going to make much difference.
However the rest of the cells are going to begin having problems quickly as they reverse charge through the dead cell, etc. It'll also affect other batteries, as they begin to reverse charge through the dying battery, or fail to completely charge (or overcharge) as a result of the charging circuit trying to get back to 48V. (If you only have 46V of nominal cell capacity (due to one dead cell), the charger is going to want to keep charging until it reaches 48V (actually higher, the fully-charged cutoff is above nominal, not going into that here). So basically it's going to overcook the rest, trying to get to that peak value that it wants to reach.
Dec 04, 2013 | Intermatic R8806P101C -...
Samsung admire shuts off on its own reads 0% when its fully charged
try to buy original battery and original charger, then try again, if problem persist show some oficial repairer maybe it is a charging ic problem due to waterdamage.for further help post comments.
Jun 28, 2012 | Samsung Admire SCH
When I hit the record button my camera shuts down. The battery is fully charged, there's plenty of memory. It'll stay on while I watch a movie, but when I hit record the screen goes blank and shuts off...
Check and clean the battery contacts as this is sometimes the fault when the camera draws more power and due to dirty or poor contacts on the battery or the camera contacts the camera shuts down due to low power. Hope that works.
Aug 09, 2010 | Cameras
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
When the unit turns on all looks well, until the gps gets a position anf then it shuts down (screen goes blank. Is there a way to reboot ther GPS
Is it connected to a power source? If not then it may need to be fully charged and then connected . Many GPS fail due to low battery power or a bad power source.
Jul 22, 2009 | Navman Tracker 5600 GPS Receiver
My i9 will not turnon
right no1 the phone comes with 2 batterys which have charge try the other battery if that doesent work connect the phne via usb to a computor it should turn on automaticaly and start to charge then you should after a few min be able to turn phone on fully keep you battery fully charged dont let it completly run down as these phones are prone to this problem
Jan 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
207 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
