Question about GE Refrigerators
REFRIGERATOR GSH25KGMCWW ICE DOOR WILL NOT CLOSE
THIS REFRIG. ICE SHUTE DOOR IS NOT CLOSING CAUSING ICE WHAT REM FOR THIS
    Genius:
  • 1,239 Answers
Hi Step 1: If the door won't shut tightly, tip the refrigerator slightly backward by propping up the front of the unit or unscrewing the front leveling legs two complete turns. Experiment with this adjustment until the door stays closed, but don't tip the unit very far out of front-to-back level.
Step 2: If leveling doesn't work, tighten the hinge screws. You may have to open the door (especially the freezer door) to turn these screws. On some units, you may have to remove a hinge cap or trim to reach the screws; pry off the cap or trim with a screwdriver. Sagging and looseness can be corrected by shimming the door hinges. Loosen the hinge and place a hinge-shaped cardboard shim between the hinge and the door. Then tighten the hinge again. Sagging may also be caused by a wrongly placed shim. In this case, you can correct the problem by removing the shim. Experiment with the shims; you may be able to eliminate the sagging.
Step 3: If the door is warped, tighten the screws that hold the inner door shell to the outer door shell. You may have to change or adjust the door gasket after making this adjustment.
Step 4: Check the catch. Newer units have a magnetic catch on the door. If the door doesn't latch properly, remove the magnetic strike from the inner door shell and shim it slightly with a piece of thin cardboard. You may have to adjust the gasket to conform with the new shim.
Posted on Oct 17, 2008
  • ABHISHEK.C
    ABHISHEK.C Oct 19, 2008
    hi
    sorry sir i sent you a mislead information that i have to send to other customer your vote changed my ranking please change it please......................
  • ABHISHEK.C
    ABHISHEK.C Nov 25, 2008
    hi sir i given a correct soluution.if you want contact fixya support  about this.please change your rating i will affect my rating badly.please change it..............................please
Rubber flap in ice shute on PSC23NG does not close causing ice build up
you might what to contact the fridge manufacturer,,make sure to write the model # and serial # and there should be an 800' # to call, as all fridges are different
Feb 20, 2013 | Refrigerators
Is your service free of charge? if yes what cause smowy ice around the freezer door in a refidgerator
This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
Mar 12, 2011 | Refrigerators
Icing up where ice cubes drop from door
door to ice shute not closing tight replace with door kit . for your model the newer model uses a better seal and a stronger spring . .. mm
Aug 11, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator door
ice door won't close ge #pss26msrbss
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice depensing door will not close on LG model LSC27926ST
It is probably frozen in place. The old ice tray bend and spils in the Ice Bin and eventually leaks out that door. Have you changed the ice tray with the update? This might fix your problem. Do you know if the door has illumination for the buttons? Mine doesn't and I think there should be somethng cause it is hard to read the buttons in the dark.
Sep 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker shute clogs and ice builds up inside door of freezer
the baffle (door that opens/closes) not working properly and allowing moisture to enter or a spring on the closer broken or the electrical solniod is failed, try this get some ice open the frzr door and if the door don't close a repair is in order,,,
Aug 20, 2009 | KitchenAid KSBP25IN Side by Side...
On kenmore refrig model 56662500, ice chute door is loose and not closing which is causing ice to melt and leak water through the chute closing
they sell replacement kits for your unit that should fix your problem , it is usually the plunger.
Phil
Jun 10, 2009 | Refrigerators
I HAD AN ICE BALL PROBLEM IN THE LOWER RIGHT SIDE OF MY REFRIGERATOR IN WHICH THEY CAME AND FIXED BY INSTALLING A HEATER. bUT NOW I HAVE ICE BUILD UP IN THE NEXT SECTION UP IN THE FRIDGE WHAT WOULD BE...
Some how warm ambient temps are finding their way in there and causing this ice up. I do know that samsung had built a few of the ge models which have evaporator coils in the refrig section. You should shut off the refrig completely and leave the freezer door closed, but open up the refrig door and let it defrost down to room temp. After trying this log how many days it takes to come back and if its in the same area.
Mar 31, 2008 | Refrigerators
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
