Question about Yahoo Messenger
Yahoo messenger for vista
Yahoo messenger looses connection and i have to login again seval times
  • billy5591 Oct 17, 2008
    setting my messenger settings has nothing to do with loosing connection in yahoo messenger for vista
  • Anonymous Dec 13, 2008
    i have a problem to signing into yahoo massenger.......
    when i want to sign in, appear a window which say that "there was a problem to singing into yahoo! massenger. please try again a little bit leter"
    anybody can help me..???
    Sergeant:
  • 213 Answers
Its a connection problem only
some time it loses
or furthur try to contact with your net service provider
Posted on Oct 17, 2008
    New Friend:
  • 109 Answers
Check your yahoo messenger settings.
Hi I am getting 81003002 error for yahoomessenger and also for mail. Can u please help me out from this error.
Hi Kiran,
  1. Try to login after some specific time , and check if you are able to login successfully,
  2. After several attempts in the login fails, then you need to restart the PC and try again while you are connected to the internet.
  3. Make sure that you have not logged in to yahoo mail from your browser/internet explorer, if you have then you need to log out and check logging in the yahoo messenger only.
  4. Remove the application via uninstall from the add / remove programs option , and then delete the registry keys related to yahoo messenger or the complete yahoo messenger folder and then install it again , as many time it would work.
  5. To remove the registry keys you need to start regedit.exe from the run command in the start menu and search for yahoo messenger for e.g. "HKEY_CURRENT_USER\Software\Yahoo\Pager"
  6. Delete the folder for pager if it exists.
  7. Resintall yahoo messenger , and try to login again and it should work fine.
Please get back to me in case you have any queries, hope this solution would solve your problem, your feedback is valuable and it would be appreciated.
May 16, 2011 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Plese solve messenger connection problem/81003004
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Jun 05, 2009 | Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Unable 2 use messenger for vista
Hi There!
As i Understand you successfully downloaded yahoo messenger foe vista, however you cannot login using your username and password.
It seems like some of your files are corrupt. Please uninstall yahoo messenger and reinstall again from the link given below,
http://messenger.yahoo.com/download/vista/
Also once you have installed the new yahoo messenger, see that you have internet connection to get connected using your username and password.
Regards,
Olafsson
Oct 11, 2008 | Yahoo Messenger
Yahoo Messenger Logo
56 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
