Hi there. I have just taken over this office and am not sure what is connected and what is not. I am trying to send a fax through my computer and the "waiting for printer to respond:Canon MP830 FAX" doesnt seem to be doing anything.
  • 781 Answers
You need to give more details on how you're trying to send the fax.
keep in mind you don't actually need a printer to send the fax if you're using your computer to send the fax.. that's the reason you need to be more precise when discribing your problem.
in general you need to be familiar with how things are connected.
if your printer is a fax machine too the minimum you need is to have your printer/fax connected to a line (to the telephone wall jack) and to be powered up.
if your printer is only a printer and you're using your computer to send the fax you need to have your modem (the connector in the back of your computer that looks like a telephone line but says not telephone but 'line' connected to the phone line on the wall) connected and have software that allows you send faxes via your computer. (windows xp has that software so you need to make sure is installed (start>control panel>add remove programs>add/remove windows components>fax services should be installed) and if the software is installed you should be able to go to start>accessories>communications>fax>fax console
confirm what is your set up and give more details.
Posted on Oct 17, 2008
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
My HP Office jet J5780 All-in-one will not send my faxes. 3 days ago it was fine, but not now . It starts to send but then it doesn''t complete. one time it said --no computer hookup and the other times it...
Try eliminating the PC by sending from the Glass ( printer ).Make sure you have a dail tone,if speaker on available use it or connect another phone to make sure.Also see if you can enter FAX SET UP in MENU reset to factory defaults.Good Luck.
Sep 19, 2009 | HP Officejet J5780 All-In-One InkJet...
Hi my canon mx310 will not fax any ideas
disconnect all equipments using the phone line (everything)
connect the fax directly to a wall jack (a working one)
Send a one page black and white text fax to 1-888-473-2963
When your fax is received by the Test Fax Service, a return fax will be generated to you within five minutes confirming that fax was received. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | Canon MX310 Office All-In-One Printer
Fax takes too long to send.
any chance of putting it in a zip file to transmit it faster
Apr 25, 2017 | Conexant (56KUSBMODEM)
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
