Question about Whirlpool GU2400XTP Built-in Dishwasher
Unit is dead: does not appear to have power
Unit stopped working mid-cycle. I have verified that there is power to unit. Is there an internal fuse which could have been tripped? None of the lights on the control panel currently light.
  • 750 Answers
Hello chicagogunn,
Welcome,
You said,Your unit stopped working mid-cycle. You have verified that there is power to unit. Is there an internal fuse which could have been tripped? None of the lights on the control panel currently light.
There is a thermal fuse!
Go to this repair web site I listed below and you will see the diagram
1. Diagram Page 02 - CONTROL PANEL PARTS
2. The thermal fuse is, Item # 6 on the diagram.
3. Click on page two on the left at this site.
4. And then in the upper right corner it says Open This Diagram in a New Window
http://www.pcappliancerepair.com/model-display.php
6 8193762 Fuse, Thermal Electronic In-Stock $ 13.25
Let me know how you do!!
Huuum
Please remember to leave a rating!!!!
ALSO:
Here are four things that the repair manual says to check.
1.
Burnt or broken wires
Check for burnt or broken wires. This would include the wires on the timer and door switch. Also check the wiring connection where the main power connects to the machine.
2. Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a volt /ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician
3.Door switch
The door switch is wired in series with all components on the machine. If the door switch is defective, the machine will do nothing. Check the door switch for continuity
4.No Electrical power
Ensure that the proper voltage is being supplied to the appliance. Check the breakers or fuses that are supplying the power to the appliance electrical outlet. You can use a voltmeter to test for voltage at the electrical outlet.
Thank you Huuum
Posted on Oct 20, 2008
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Have a Kenmore washer, model 501-4002 which just stopped working mid-cycle. I heard a pop coming from machine that sounded like a fuse blowing. Does this model have a fuse?
Normally all the power units come with a protection and it is necessary to remove the mains power before you can investigate into the board. If the fuse had blown or there is a safety trip then check for some serious short within the power, the motor or inlet valve/drain pump circuit.
Oct 31, 2013 | Kenmore Washing Machines
I stopped it mid cycle to add more clothes. Now it keeps flashing H then F. It was fine till I added more stuff.
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maching stopped mid cycle & now has no power, it will not turn on, all fuses are ok
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 02, 2010 | Hoover Washing Machines
E60 keeps flashing and beep noise. Machine is mid cycle and has come to complete stop
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
Or
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
  • Verify CCU operation
Nov 13, 2009 | Electrolux Washing Machines
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Mid-way stoppage
Or
Mar 26, 2009 | Washing Machines
Letters H & F start flashing mid cycle which stops the cycle
error code  -----  F/H ----------- reason ----------- No water detected entering machine or Pressure switch trip not detected.
Or
solution to resolve  -----------   Press PAUSE/CANCEL twice to clear the display.
Mar 14, 2009 | KitchenAid Washing Machines
Stops about half way thru cycle anf error code HF appears
Or
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,709 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
