Question about HP Compaq WF1907 Monitor
I tunes has detected a problem with audio configuration audio/video playback
I have no sound in i tunes and i cant opperate the volume on the key board and everytime i try to go into i tunes it comes up as itunes has detected a problem with audio configuration audio/video playback may not be working properly
  • 3 more comments
  • Anonymous Nov 17, 2008
    The same thing happens to me and i tried to download the new version and that didnt help. It also says that i dont have a audio device hooked up to my computer. I dont know what to do.
  • muzzysgirl Dec 30, 2008
    i have the same thing on my comp i downloaded i tunes and it says
    I tunes has detected a problem with audio configuration audio/video playback may not operate properly.
  • lover_boi_31 Apr 24, 2009
    when i click on the itunes icon a little tab shows up and says itunes has detected a problem with your audio configuration, Audio/Playback may not operate properly
  • Anonymous May 12, 2009
    Same problem as above. In the world of computer geniuses, no one knows how to fix this???
  • kasdfkkljsdf Dec 06, 2009
    The above solution has NOT worked for me. This problem occured when I accidently un-plugged my speakers while playing a song on Itunes. After I replugged them in I got that message. Anyone have any other ideas?
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Posted on Aug 09, 2009
  • bryant61 Jun 28, 2011
    Dang! This is so frustrating and it looks like it has been going on for quite sometime!!! This was 2 years ago. I have tried everything! The instructions above...No Luck! Remove Itunes and Quick time....No Luck! Downloaded drivers from Dell...No Luck! Repair of Itunes...No Luck! Please someone HELP ME!!!
Where is windows audio?
Posted on Mar 14, 2010
Dragonicwolfs solution worked for me .. thanks
Posted on Aug 20, 2009
Ok I'm not a 'puter wiz, but this is how I fixed this problem. Go to control panel, system, click the hardware tab and then device manager. There is a list of hardware devices, look for "microsoft kernel wave audio mixer" and uninstall and then reinstall (easier said then done, but I managed to do it) and viola, my itunes is back baby!!
Hope this helps someone.
Posted on Jan 21, 2012
No sound on computer
hi nina.this could be a lot of reasons why you have no sound.
Update the audio driver using Device Manager as follows:
  1. Connect to the Internet.
  2. Click Start , and type device manager into the Start Search field. ...
  3. Double-click Sound, video and game controllers. ...
  4. Right-click the name of the audio device listed under Sound, video and game controllers.
  5. Select Update Driver Software...
  6. If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones. ... Under Hardware and Sound, click Troubleshoot audio playback.
  7. If you hear sound through the headphones, the sound hardware on the computer is working, and the issue is probably related to the speakers or speaker cables. Disconnect the headphones and reconnect the speakers. When done, test again forsound using the same steps as above with the volume control slider.
  8. If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button..
  9. or go to this link if you need mote help.
No sound on computer Google Search
Nov 05, 2017 | Computers & Internet
Skype not working
Click this link for more information........
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
How do I get my volume to work on my computer
most audio control programs (ie. realltek) are designed to automatically mute the main audio output if it detects that there is a device connected to the headphone jack, i suggest unplugging any such device. more over .... in some instances windows will allow you to set which playback device your audio stream is being sent to via the playback devices system dialog box. this video will show you how although the guy is this video is note entirely correct the process is much the same Fix Windows 7 Audio Playback Devices CLICK CC BUTTON FOR SUBTITLES
Jan 22, 2016 | Computers & Internet
Systemax ascent sais the sound card is already in use and cant seem to get sound
which operating system ??
XP If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer W7 click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Dec 23, 2012 | Systemax Ascent PC Desktop
I bought a Gwc aa1500 5.1 audio usb adapter for my laptop. I tried plugging my axpro headphones into the adapter but all the audio seems to be coming through the front speakers. How can i get it to go...
This is an issue with the driver or configuration.
Make sure you have the latest updated drivers for the device
When sound is coming from front for 5.1 system, its most probably to do with settings.Stereo mode Outputs from front speakers only. Try finding a radio button inside sound settings for 5.1 Audio system.
It is most probably found under " Speaker Configuration" Settings.
Mar 12, 2011 | GWC AA1500 External Sound System
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
Audio configuration problem
I would suggest u to the restore your computer because somebody or you might uninstall the sound card software by mistake. Go on start then all programs then accesories then system tools and then restore
Mar 17, 2009 | Microsoft Windows XP Professional
No sound
There would be sound on playback in camera and may be Volume is too low. To increase volume, touch P-MENU then VOLUME and increase ---> it.
No sound when playing back imported file in PC can be issue of sound driver of Windows or sound codec for media Player in your PC.
You can download Cole2k codec pack (audio included) and install it in PC. This will enable your PC to playback all kind of media files.
Dec 07, 2008 | Sony Handycam DCR-SR40 Camcorder
Won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Sep 01, 2008 | Philips SpeechMike Pro 5274 Handheld Voice...
HP Compaq WF1907 Monitor Logo
3,544 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
