Question about Panasonic PT-60LCX64 Television
Read replace lamp then afew weeks later heard pop noise and now black screen
2005 model panasonic PT-60LCX64 had replace and reset lamp warning every time we turned it on. I did not change then sae a small yellow spec in top left corner then a few weeks later while watching heard a pop and the scrren went black. i shut off and turned back on but hear a weird grinding noise every 30 seconds there is no picture and front green light just flashes? HELP
My email is kukuii@tampabay.rr.com
  • kukuii Nov 09, 2008
    YES! It was the bulb and glass was everywhere. THANK YOU!
  • rvburgess Apr 21, 2009
    when I turned on tv picture was dark, then a few moments later heard a pop and picture went black, like it was'nt on at all
    Scholar:
  • 86 Answers
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Posted on Oct 17, 2008
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
PT-60LCX64 no sound
check to make sure speakers in the menu are not switched to OFF. and inside set look to see speakers are plugged into a board somewhere.
May 31, 2012 | Panasonic PT-60LCX64 Television
Our panasonic HD tv displays every time we turn it on that the LAMP LIGHT needs to be replaced.....we replaced it.......it still pops up and last for about 2 minutes every time we turn on tv
Sir reset the lamp hour meter this will resolve the problem. Follow this instruction.
  • 1.Turn on your Panasonic television.
  • 2. Press and hold the - volume button on your television. Continue to hold the volume button and press and hold the "PIP" or "SPLIT" button on your remote control.
  • 3. Hold both button for five seconds and release. A message appears on your television screen indicating the meter has been reset.
  • Sep 16, 2011 | Panasonic PT-60LCX64 Television
    Lamp reset on a panasonic model pt-50lc14-k
    This works for mos Panasonics
    Turn on Power
    Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
    Screen should say " Lamp time was reset to 0"
    Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
    Panasonic PT-60LCX64. What would happen if you
    you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
    Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
    How do i access the lamp on a panasonic pt-60lcx64?
    Pull the front panel off and you will see a srew on the left side. Remove that screw and a smaller cover will come off. Then remove the srew that behind the small cover and then you can pull the lamp assembly out.
    Aug 14, 2009 | Panasonic PT-60LCX64 Television
    How to reset lamp meter
    I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
    Dec 29, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
    How to reset the meter of lamp
    You need to have your Panasonic remote.
    1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
    2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
    PIP for Models:
    PT-50LC13/PT-60LC13/PT-50LCX63/
    PT-60LCX63/PT-43LCX64/
    PT-50LCX64/PT-60LCX64
    SPLIT for Models:
    PT-43LC14/PT-50LC14/PT-60LC14
    3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
    You will find a PDF of the instructions at this site:
    http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
    Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-60LCX64 Television Logo
    457 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
