HOW DO I INSTALL A JVC-KD-G340 IN A 1995 BUICK LA SABRE??? STEP BY STEP PLEASE I HAVE THE WOODGRAIN PANEL AND THE BLACK PLASTIC OUT WITH THE RADIO DISCONNECTED. NEXT STEP PLEAE....
    Problem Solver:
  • 12 Answers
Idk where ur stuck ? U got all the trim off, if u pull the old radio out n disconnect the harness it's as easy as getting yourself the adapter specific to ur cdplayer and ur car, u can buy em at best buy, ebay or any home/auto audio store. Also never take advice from a ****, it's like taking a trip to the dark ages where people don't know how magnets work.
Posted on Mar 16, 2011
  • 86 Answers
If you got yahoo, message me at ****_family_woop_woop an i can walk you thru it, It be alot easy'r to talk wit you then to put in details here, Hooking up Cd players is a piece of cake so just hit me up, the reson 4 this is because i dont know if u have a wiring harnest or if ur wiring it directly 2 the factory wires thats the reson
Posted on Oct 17, 2008
Need instructions on how to wire a jvc kd-g140 radio
http://resources.jvc.com/Resources/00/01/13/GET0485-001A.pdf
install instructions for your radio is on page 4
Jun 07, 2010 | JVC KD-G140 Car CD Player
How do I replace license light bulbs in my 1995
I have a 2002 which is a little different body style but it may be the same process. You have to take the back plastic section that holds the license plate loose from the car. There are bolts that are inside the trunk that hold the plastic panel on. Mine are in the trunk lid. If your plastic panel, license plate, etc. goes up with the trunk lid they are in the lid. You need deep type sockets to reach the nuts, at least mine does.
Mar 31, 2010 | 1995 Buick LeSabre
Removal of the stereo of a Buick LeSabre. what part of the dash do i need to remove and how?
the trim around the heater controls snaps in, its black. Remove it and remove the four screws on the woodgrain panel. Lift off to acess radio.
Nov 22, 2009 | 1991 Buick LeSabre
Jvc kd-g415 car radio owners manual
There Is not a model of that kind
May 25, 2009 | JVC Car Audio & Video
Set clock on radio
Hello atesha23,
Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
(1). Enter the PSM mode by pressing and holding the
SEL button until the display changes.
(2). Use the rocker switch left/right until "CLOCK
H" is displayed.
(3) Set the clock hours by turning the volume
control up/down.
(4) Press the rocker switch again until "CLOCK M"
is displayed.
(5) Set the clock minutes by turning the volume
control up/down.
(6) Press the SEL button to finish and EXIT.
Hope this helps.
Mar 31, 2009 | JVC KD-G140 Car CD Player
How do I install a JVC KD-G140 car cd deck
You  are not in over your head. You just need to make sure you pay close attention to detail when connecting the wires.
First thing to do:  Go to a place that installs car stereos and tell them you need the complete install kit including the wiring harness adaptor. Most all of these places will sell them to you. It is what they use to install the radio. They must know what type of car you are putting it in. Give the the mjake and model and year. They will then give you a bag full of plastic parts and another small bag with a wiring harness. MAKE SURE you get both. You really do need them. The plastic parts are for mounting the radio in the car properly. Without it, you will have something sloppy and it will not look right. It should have instructions. The kit will usually be able to be used for several different models of cars and any model of radio. You must pick which part is right for your car and radio. As I stated, it will have instructions.
Next, after you have the plastic mounting parts picked out for your radio, you will need the wiring harness for your radio and the wiring harness adaptor that you just purchased. The wiring is easy, just match the colors from the harness of your radio, to the same colors on the adaptor harness. Make sure that the wires are stripped properly and they are twisted together properly (or use small wire nuts or crimping type if connectors). Connect red wire to red wire, yellow wire to yellow wire, black wire to black wire, and son on until all wires are connected. Then for extra safety wrap each wire with some black electrical tape to ensure that if a pair if wires came loose somehow that they would not touch anything and short out causing the radio to need service.
Now you just plug the proper end  of the harness into the radio and the other end into the harness in the car that the factory radio was plugged in to. Make sure to plug in the antenna as well. Make sure the cage that the radio is  in is secure in the plastic mounting brackets you have purchased. Then the radio will go right into place and the bracket will screw in where the factory radio used to be screwed into.
If you need more help, just ask.
Dave
Jan 20, 2009 | JVC MXKC45J
CD loading.
je cherche la plate avant du radio model:kd-s580 marque jvc
merci de votre collaboration.thank you
Mar 25, 2008 | JVC KD-S580 CD Player
65 people viewed this question
 Grubhead
Grubhead
