Cant install powercolor 9600 pro on ECS 845gv-m3 mobo
Cant install powercolor 9600 pro on EliteGroup 845GV-M3 mobo... Fan will run in agp express slot but hardware not found on boot up, or driver install (win XP). if I set bios to detect card then no signal at all (from onboard or 9600 pro) Nvidia mx4000 128 Mb card works fine, but only 128MB.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Background info, a Powercooler 9600 PRO EZ was most probably manufactured by C.P.Technology in Taiwan. I am sorry to say that quality wise, this company is rather low and to my understanding, a lot of their products has to be returned/replaced even new. On the other hand, the old Nvidia MX4000 might have been manufactured by Palit, also in Taiwan but has a better quality control as of the time of production. The MX4000 though only uses 128Mb of memory but runs them at 275/400 (DDR) MHz clock speed compared to the 9600 PRO 200 (400) MHz. The slow memory onto the PowerColor RADEON 9600 PRO EZ 256MB had a really bad effect on its performance.
To your concern, the ECS 845GV-M3 (V1.0) uses AGP Express but should not cause a problem to either the 256 or 128. since it is working with the 128, then it would be safe to say that the 256 is defective. if the 256 will test OK in another motherboard, then it would be a compatibility issue, try setting the CMOS/BIOS to default and see if it will work.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 17, 2008
SOURCE:
I need a vidio driver
I prefer to get the drivers from the chipset fabricator (here it's likely Intel's site--Intel onboard video(?))--not the motherboard fabricator's site.
Only extremely rarely is the chipset fabricators' drivers not the best solution. Nowadays, though, the board fabricators site likely offers decent and workable drivers--board fabricators have become far better at upgrading them than in the past.
Mar 04, 2014 | ECS 845gv-m3 Motherboard - Gq5080 Intel...
I installed win xp but the drivers for 845gv-m3 v10 does not work that i download from your site? Please help
btjunkie.org is my resource for all of my XP drivers I answer this question a lot from folks that need drivers. If you can I suggest upgrading anyway to Win 7 they are downloaded mostly for you during the install process which makes it a lot easier these days to fix machines. Less time in any event go to that site make sure that you have U torrent a torrent file down-loader program software. Type in the search box once at the btjunkie site XP drivers you will have thousands of them to download on one disk insert the disk then go to devices seek the drivers needed to be found point the seek to your drivers disk and hopefully it can be had. I never have an issue with drivers using the software downloaded from there site. I hope this assists you. It is also for those of you who read this post to keep your driver files with your purchase when you bought the computer. If this is not the case then you will have to hunt them down.
Jan 15, 2011 | EliteGroup ECS 845GV-M3 (1.0) ATX...
Motherboarddriver for 845gv-m3
Hi.
Below the link to manufacturer website support page. Scroll page and choose download tab, right below the motherboard picture in ECS website, then choose driver.
Click here to open Elitegroup 845GV page.
Regards.
Ginko.
Nov 01, 2010 | EliteGroup 845GV-M3 Motherboard
No display
Have you installed your display driver, it might be a problem from that. Install your proper display driver and check it may solve your issue. It might also arise from your display card if it is not functioning properly. And the last check your monitor that it is in proper condition or not.
Jun 24, 2010 | EliteGroup ECS 845GV-M3 (1.0) ATX...
Lost power cord
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alklkl14
Apr 15, 2009 | EliteGroup 845GV-M3 Motherboard
How can I overclock 845gv-m3 motherboard?
according to ecs this is a 478 / fsb 500 ht mobo and cannot be overclocked (now most can be with a bios flash but be carfull the speed you get my not be worth it I find most only get 2-300 mghz & you chance ruining a good mobo).
Oct 24, 2008 | Computers & Internet
Cant install powercolor 9600 pro on EliteGroup 845GV-M3 mobo... Fan will run in agp express slot but hardware not found on boot up (win XP)
HI findads,
You need to make a change in your bios. Still have your manual for the 845GV-M3 motherboard?
If not you can download it at this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=465&DetailName=Manual&DetailDesc=845GV-M3%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
You will also need Adobe reader to view the pdf file. Get Adobe for free at: http://www.adobe.com/products/reader/
If you have already installed the 9600 AGP card, please shut down your system. Unplug the power cord from the power supply. Open your case & remove the 9600 AGP card. One must follow an order of sequences’ when changing graphics cards. Once removed, reconnect the power cord to the power supply & boot the system. (It’s ok not to close your case). As the system starts to boot, press the Delete key on your keyboard every two seconds. The main bios menu will load. Read the instruction at the bottom of the menu which will show you how to move about in the bios.
(The mouse does not function while in the bios).
Using the manual to help change a settings.
Go to Advanced Chipset Features page 35, than into Integrated Peripherals, page 37.
Set Init Display First to [AGP]. Save the bios & exit. The system will auto restart. Once your screen goes to black, press & hold the power on / off button on your case until the system shuts off.
Unplug the power cord from the power supply. Install the AGP video card. Make sure it is completely seated & even in the AGP slot. Screw it down. Before closing the case, re-check all internal power connections to every device & all data connections. (Snug fit). Close your case & reconnect the power cord to the PC. Boot your system. You should have display & windows should load.
Install the CD software for the 9600 Pro video card. Restart the PC. Go to power color & check for any driver updates for the 9600 Pro card. http://www.powercolor.com/
Before installing any update from PowerColor check windows for updates.
Everything should work out ok.
Good luck findads!
Questions? Post here.
Mike
Oct 16, 2008 | EliteGroup 845GV-M3 Motherboard
Mother board bios update
From datasheet on Intel 82865GV: > The 82865GV does not support AGP. ECS use selfmade "AGP-express" port, which isn`t "real" AGP. It is answer that this motherboard need to support videoadapters by BIOS. Recommendation - do not use this motherboard (and other on i865GV chipset) with "external" graphic.
Aug 03, 2007 | EliteGroup 865G-M Deluxe (865GMV50)...
Open Questions:
Computers & Internet Logo
183 people viewed this question
Alun Cox
