Question about APC Computers & Internet
APC BN600 I just purchase this unit and as i followed the instroctions and plug it in the wall outlet it (bips). I know I have power at the wall outlet but all the indication tells me otherwise. According to the instructions 4 continues bips every 30 seconds is a sign that the unit is using battery power. why does it bips if I have power at the outlet?? help. pc
ijay
  • 82 Answers
SOURCE: UPS TRIPS AFTER 30 SECONDS
dear, This problam is related to battery and i am sure your battery is faulty pls replace it.
Posted on Sep 25, 2007
  • 124 Answers
SOURCE: 'Battery' outlet dead.
Hi There, Its definately the battery. The batteries can be replaced.
Posted on Nov 05, 2008
gotgeek2
  • 565 Answers
SOURCE: APC Backup UPS Model # BK200C salvageable?
Yes, but the battery may not be any good, though, and trying to charge it may damage the charger. A new battery is about $20. The surge suppressor will still work without the battery as long as it is connected to a properly grounded 3-wire circuit. If you decide to take a chance and charge the old battery, take precautions like keeping a watch on it should it explode or catch fire. Not trying to scare you, just looking at worst case scenario.
Posted on Jan 27, 2009
SOURCE: Common Failure mode of APC 500 UPS
I would recommend replacing APC UPSs with ONEAC ONEPlus Power Conditioned UPSs, which have a perfect ground reference, longer lasting and more reliable batteries, and a 5 Year Warranty (2 Yrs on Batteries).
www.gryphon-inc.com
1-800-POWER-OK
Posted on Jan 30, 2009
  • 5 Answers
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
Posted on May 12, 2009
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Hi,do I have to keep my ups plugged to a wall socke all the time?
    hi,
    the unit needs to be plugged in all the time. the unit is or should be fully automatic. higher priced units have a usb cord so you can check their status right on the computer, does your ups have a usb outlet? you might want to take it up to a computer store and buy a usb cable and then you can control your UPS with your computer. manually turning the UPS on and off shouldnt hurt anything.
    good luck
    jm
    Aug 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
    Need information
    The Back-UPS is fairly straight-forward. The 9-pin connector (at the top of the back) is a serial port (RS-232) for the UPS data (when connected to a computer it will shut down the computer safely during a power outage). The next plugs are RJ-11 telephone jacks; the cord from the jack (wall) goes in on the left (some models have RJ-45 for network protection). The battery protected outlets are the three surrounded by black paint. The other three provide surge-protection only. Do not plug items like printers and scanners into the outlets that provide battery protection.
    I hope this helps.
    (for software, manuals and other information:
    http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BP650S&tab=models )
    Apr 17, 2010 | APC Back-UPS Pro 650 UPS System
    Need charging instructions for apc back-ups es 350
    Take off the bottom cover and make sure the battery is connected (both terminals).
    Plug the unit into a wall outlet.
    Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
    Done.
    Aug 08, 2009 | APC Back-UPS ES 350 UPS System
    Outlets ot labeled on APC BK200
    On this unit both plugs are on uninterrupted power.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Over 21 years of PC and printer support/repair
    Jun 09, 2009 | APC Back-UPS 200VA (BK200) UPS System
    UPS are cickling and beep when I tried to start the computers
    When they beep it usually means they're running on battery power. So check to see if the power outlet (at the wall) has power (Just plug something else into it). If not, check your fuse/power box for the building. If its all UPS at the same time, its probably the buildings outlets.
    Mar 22, 2009 | APC Computers & Internet
    APC Smart-UPS RT 1000VA
    Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
    power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
    Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
    My APC keeps beeping.
    possibly..you have unpluged or dislodge you power cable from the outlet or from the power plug shuye at the back of your ups.. double check all the plug and re plug all your power cables !!!! make sure they are tightly pluged in and firm in their outlets..
    Jan 26, 2008 | APC Back-UPS Pro 650 UPS System
    Computers & Internet Logo
    253 people viewed this question
    Top APC Computers & Internet Experts
    Jax Planet
    Jax Planet
    Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
