Question about Recoton Advent Advent Q2035A 20" TV
Advent 32" tv flat screen
The tv lacks the red color component and the picture is always greenish
how to fix this ?
  • 92 Answers
It's likely one of two things. There are drive transistors on the CRT board which control the output to the guns, the one that controls the red gun may be open, also check this board for burned resistors. It could also be a bad picture tube although this is less likely. If it is the tube, replacements if available are fairly expensive.
Posted on Oct 17, 2008
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
My tv screen look like yellowish blue greenish color
Your Tv have color problem theres a lack of red color and the problem is is in the chroma section of the board.Ethier cold solder or deffective chroma ic.
Jul 06, 2011 | Televison & Video
My flat screen hd sharp aquos color turns green when we are watching it. it is only 3 three years old. what can this be? thanks
I'm not sure if this is the same, but people were green no matter how i adjusted the tint, and lacked overall color. I doubled checked the component cables, taking each one out, and putting it back firmly,
Picture is back to normal. Easy fix.
Feb 10, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My tv has sound but no picture. The screen is greenish in color.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The screen is all brown with no picture
preciso mudar o sistema de cor ntsc para pal m
Dec 31, 2009 | Recoton Advent Advent Q1435A TV
TV picture goes out after like 5 minutes of being on
Get speakers away from screen, Yes magnetism causes this problem. You must use shielded speakers if they are close to a TV.
Mar 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
for the settings click this link
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Mar 19, 2008 | Akai PDP4295ED 42 in. EDTV-Ready Plasma...
Recoton Advent Advent Q2035A 20" TV Logo
208 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
