Question about Whirlpool Kitchen Ranges
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor instaled. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
  • 750 Answers
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Posted on Oct 17, 2008
How do I fix my stove?
I would suspect the keypad having intermittent key contact, especially if this is a GE or older Whirlpool wall oven, check by model # on a parts site to see if a key panel is available for it and start there...
Apr 22, 2016 | Kitchen Ranges
My whirlpool electric stove keeps beeping it shows f2E0 why is it doing that?
The F2 E0 error means that the control board believes that a key on the touch pad has been held down for an extended period or has shorted. Assuming that no one is holding the buttons, try pressing Cancel to clear the error. If the error recurs promptly, check the wiring harness between the key pad and the control board to make sure that the wires are tightly connected. If the problem continues, you probably need to replace the touch pad (key pad) assembly. On some Whirlpool models, the keypad and the central control board are sold as a single assembly. In that case, you'll need to replace the entire unit.
If you add a comment with the model number of your stove, I may be able to give you the part number for the keypad. I hope this helps.
Jul 17, 2015 | Whirlpool Kitchen Ranges
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Microwave oven panel starting beeping from and doesn't work
You either have a shorted keypad or another problem with the control panel assembly.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | Whirlpool Microwave Ovens
Kitchen Ranges Logo
728 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
