Question about Refrigerators
Sears Kenmore Elite model 44103 no longer cools/freezes. Front panel LEDs blink and buttons are non-responsive. I replaced the Control Electronics board in the plastic box on the bottom, but no change.
  • huffdave Oct 17, 2008
    Fan still works, but the compressor is not
    running. Fridge is only 4 years old. I
    just got the front panel off, but I can't
    remove the black plastic insert - it feels
    like it's glued to the refrigerator. How
    do I remove this to get behind it???
    Genius:
  • 1,239 Answers
Hi To gain access to the lower section of the refrigerator, remove a service panel held by retaining screws at the back of the unit below the condenser coils. The unit may also have a front access panel below the door. This panel may be held by retaining screws, or it may slip up and off two side brackets. On some models, you can tip the refrigerator over and test and service parts from the bottom. In this case, the refrigerator must be defrosted, unplugged, and emptied before any servicing can be done.
Posted on Oct 17, 2008
  • ABHISHEK.C
    ABHISHEK.C Oct 17, 2008
    hi or try this
    On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
    Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
    Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale (instructions for using the VOM are given on page 19).
    Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
    Step 4: Connect the new switch the same way the old one was connected.
  • 905 Answers
The compressor don't usualy just quit , but the capacitor does
  • jason Oct 17, 2008
    you must first make sure you have checked all the sensors
    because it is digital it also has safety sensors that prevent any further dammage from happening when a device inside has failed
  • 958 Answers
Hi huffdave,
you just replace the power board underneath the unit near the compressor. but there is still another board which is the key board where you press the buttons which is not responsive now. i am not suggesting yet to replace the board . simply pull the cables off the board and sometimes that would do the trick.
if it is still the same, let me know so that i could help you further. pls use the "ask me " button to direct a question to me.
tnx 4 using fixya,
drcool
    Master:
  • 505 Answers
These are the certain steps :
Step1 If the fridge won't run, first check the power cord, and the reset the circuit breaker.
Step2Check for thermostat problems. It could be off or won't cool properly (too warm, too cold). If it can't be fixed with a simple adjustment, call a professional. Step3Check for coil problems. The compressor can overheat due to dust buildup on condenser coils. If so, vacuum the coils. If there's ice buildup on evaporator coils due to bad defrost heater, call a professional. If there's a squealing sound inside the refrigerator, it's like a failing evaporator-coil fan. If so, call a professional. Step4If there's frost buildup in the freezer, this is due to a bad defrost heater, in which case you should call a professional. Step5Realign the water tube if it's out of position. It could cause problems with the ice maker. Step6Replace any worn-out gaskets.
Go to this link, it answers different problem and how to fix them.
http://www.applianceaid.com/refrigerator.html
Since you have already replaced the Control electronics board, you need to check the compressor for which you may require a technician to come over to your place.
Thanks
  • Indrajit Roy
    Indrajit Roy Oct 17, 2008
    Sie I would recommend you to consult a repairman. The black thing is glued and dont try to forcefully remove or else it may damage the internal parts.
    Tips & Warnings
    Don't attempt to make repairs to the compressor, evaporator coils or condenser coils. They are sealed and best left to a professional repair person.
    Unplug the freezer before accessing any of the internal parts.
    Thanks
    Sergeant:
    Champion:
  • 258 Answers
I think the compressor has a problem
  • Efren Javier
    Efren Javier Oct 17, 2008
    consult a repairman compressors reglulates thermostat that's why ref cools and freezes
  • 1,800 Answers
Check the fan if still working and also check if the otor still runing or the gas is insufissant
Tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
on Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Microwave model 88523 has failed 2 times with an error code of TE. Sears fails to accept responsibility for the manufacture of a defective product, instead put the blame on me for not p
make this test . God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
  4. main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  5. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Dec 12, 2013 | Microwave Ovens
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My whirlpool duet dryer won't go off the control lock. I've held the button down for longer than 4 seconds, unplugged the machine and still nothing??
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)()(^$#
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
Sears Kenmore Elite Refrigerator model no longer functions. Front panel blinks and all buttons are non-functioning. I already replaced the Control Electronics board, but no effect.
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Oct 17, 2008 | Refrigerators
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
