Question about Refrigerators
Sears Kenmore Elite Refrigerator model no longer functions. Front panel blinks and all buttons are non-functioning. I already replaced the Control Electronics board, but no effect.
  • 2 more comments
  • huffdave Oct 17, 2008
    Model number is 106.44103300. I've removed the front panel circuit board, but I can't find the Kenmore part number on the board. Does anyone know the Kenmore part # for this circuit board? The number on the board is 08535499 but does not come up in any searches. Thanks.
  • huffdave Oct 18, 2008
    Thanks - that's what I did - the part should be here on Tuesday.
  • MB001 Mar 29, 2009
    Yup I have exactly the same problem. Fridge appears to be operational but all the lights are flashing (consistent with a power failure ?) but none of the controls respond (including "lockout" even with long holds) except the on-off switch. Any insights would be welcome - thanks Mark
  • Anonymous Mar 16, 2014
    Maytag refrigerator, model MFI2269VEQ. The Control Panel on the front is dead. Can I fix this?
  • 120 Answers
Need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
  • Rosendo Madero
    Rosendo Madero Oct 17, 2008
    just give the person where you are buying the board and they will give the right board the number on the actual board subs to a diferent number
Kenmore Elite Microwave model 88523 has failed 2 times with an error code of TE. Sears fails to accept responsibility for the manufacture of a defective product, instead put the blame on me for not p
make this test . God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
  4. main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  5. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Dec 12, 2013 | Microwave Ovens
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 | Dishwashers
Whirlpool Duet Dryer Lockout function stuck
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet washer model GHW9150PWO show the that the controls are locked. There is nothing that functions when this is going on all other buttons are inoperative.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((*(*))))
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The control lock lite is on my kenmore elite washer. How do I reset it, so that I can use the washer?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Flashing PF
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears elite keypad not functioning
Sounds like you have a defective control panel.
We repair these for customers nationwide with our guaranteed $39.95 service.
In some cases, it may need parts, but we would contact you first for your approval for any additional charges.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 01, 2008 | Kenmore 63672 Convection/Microwave Oven
Refrigerators Logo
443 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
