Question about Dell Inspiron 1501 Notebook
Ac adapter When I reboot my pc, I get the prompt "ac adaptor not recognized by pc, pc may not be able to recharge"...it is the adaptor that came with my new pc...new a year ago...I was getting same prompt for battery, but flashed bios and there was a fix for that...What about the adaptor, my pc shows charging at times and then not at times...
  • burnedmind Nov 21, 2008
    My 1501 won't recognize its battery. It is th origial that came with the computer, and "battery status" show a full charge. "Battery health", however states the computer doesn't recognize the batery, and cannotcharge it. The comuter work fine on AC power. Any advice would be greatly appreciated. Thanks!
  •  supermex
    supermex Dec 02, 2008
    we had the adaptor checked and the ac cord from the wall to the adaptor was not showing much power at all...we r in the process of buying a new adaptor or a refurbished from Dell...I have seen the reviews on the adaptors, not good...life span is very short for a $65 refurbished part...
  • Dell Master
  • 4,338 Answers
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
The laptop would have to be taken apart and the DC connector resoldered.
This would cost $75 - $100. Enter your zip code in the box on the right hand side of the FixYa page to find someone close to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 17, 2008
I had this problem and call Dell two weeks ago. We went through a bunch of steps and the tech said I eiher needed a new battery or motherboard. Since my lap top is still under warranty they sent both a new battery and a box to return the computer to the factory if the new battery didn't work. The new battery needed to be run out and then completely charged and has been working fine ever since. I no longer have that message upon computer start up and the new battery is charging just fine.
Posted on Nov 30, 2008
Lost ac adapter
AC adapters can bought from most of the electronic spare part shops. Gopakumar Gopalan Google
Aug 06, 2014 | Panasonic DVD-LS86 Portable DVD Player
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
My computer says it dosent recognize my ac adapter
well introduce them(just kidding)
check that the plug is seated on the adapter going into the laptop
otherwise, there may be an issue with plug, adaptor or the place it inserts
might need a new adapter not that expensive really
May 23, 2012 | Dell Inspiron 1318 Laptop Computer PC...
When try t charge my battery in my Vostro 1000, I get a message " The battery cannot be identified the system will not be able to cahrge the battery
Try this first:
Use up the battery until the the screen would black out. Afterwards, reboot the laptop ( without using the AC adaptor) and the system will warn you of low battery - to press F1. After pressing F1, plugged the AC adaptor back and try rebooting.
If the above does not work, there is a Bios update from Dell that suppose to fix this problem.
Oct 20, 2010 | Dell Vostro 1000 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
AC adapter not recognised
Try charging the battery on one of the other dell's.
If the unit runs for any lengh of time, it is not the motherboard.
It could be the A/C adaptor jack on the side of the unit.
Log a complaint will dell's customer care.
Sep 28, 2009 | Dell Inspiron 6400 Notebook
The ac adaptor is not recocnized
What do you mean it is not recognized....do you mean it is not charging your laptop? that could either be a bad adapter or a faulty ac jack on the motherboard.
Aug 30, 2009 | Dell Inspiron 6400 Notebook
Will not recognize AC POWER, Running from Battery only- now battery is dead.
The adapter might be faulty
Check the adapter with multi-meter, the voltage reading should be slightly higher than the voltage output that is printed on the label on the adapter.
May 02, 2009 | Toshiba Satellite M35X-S311 Notebook
I bought a targus ac adapter, it worked the first time I charged my Dell 5100 Notebook computor, now a message comes up saying it doesn't recognize the ac adaptor, how can I fix this?
AC adaptor may not be correct. Check label on AC adaptor with label on notebook for voltage (e.g. 19.5V or 20V) and current (e.g. ??A or 90W)
Voltage must be same and current must be same or higher on ac adaptor.
Aug 09, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
525 people viewed this question
Alun Cox
