Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
Sounds funny/shutting off after few minutes
I have a Bissell LiftOff Revolution Pet Vac that is about 2 years old. All of a sudden it only works in the floor mode (won't turn on in wand mode) It also sounds funny, if I do get it turned on, it usually only lasts a minute or two before shutting itself off. I don't see any clogs and the canister is not full. Any suggestions?
    Problem Solver:
  • 4 Answers
Yup! Clogged hose on the back of the cannister! Unit is designed to shut off for 30 minutes when this happens to protect your motor. Remove top of hose where debris enters the cannister through a filter above it, then remove the other end of the hose from the bottom of the back of the cannister, take it outside and use something long that'll fit inside the hose to force out all the clogged debris and hair through the top of the hose.
Posted on Jun 07, 2009
Has no suction
check the suction pipe behind the brush bar it's probably clogged ,this link is the manual..........
Nov 26, 2012 | Bissell LiftOff Revolution Pet Vac 37602...
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
Just quit running while in use
My bissell just quit. No smell. Don''t understand. Had a new bag.
May 28, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Apr 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My liftoff revolution smell like it is burning after I use it
That means that the belt is worn and is starting to slip. You need to replace the belt. Here is the belt you need and a manual you can view with instructions:
Bissell Lift-Off Revolution Belt and Manual
Mar 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Vaccum works but will not **** up anything. i have cleaned hoses and filters
have you checked to see if the belt is attached to the brush roller? That's a common problem. Check your belts
Feb 10, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
How do I fill the tank
I downloaded the user manual from the Bissell site
May 18, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
361 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
