Question about HP Office Equipment & Supplies
I open the top to put the ink cartridge in and then I close the top and then I press the ok but then it read's that the cartridge is jam so I open's the top and take's the cartridge uot and then put it back in and it still read the some thing so now what.
    Master:
  • 505 Answers
Make sure the drum is clean. You may have to realign the print cartridge by going to the printer properties.
Thanks
Posted on Oct 17, 2008
HOW TO CHANGE INK CARTRIDGES ON EPSON 305
For the Epson Stylus NX305, turn on the printer, if it is currently off. Next if the LCD message reads replace ink, press OK and then lift the scanner unit until it locks into place. Open the ink cartridge cover (it pivots towards the user). Then squeeze the tab on the cartridge to be replaced and lift it up. (Press towards the center of the cartridge.) Next take the new cartridge and shake it 5 times while in the package. Open the package and carefully (without touching the green chip) remove the yellow tape from the bottom of the cartridge. Insert the new cartridge into the appropriate slot and press down until it clicks. Repeat this for all cartridges that need to be replaced. Then close the ink cartridge cover and press down until it clicks as well. Lower the scanner unit. Then press OK to charge the ink system. This step will take about 2 minutes. Then press Menu to exit the menu system.
If you are replacing ink cartridges that are not empty. You need to enter the Menu and select Replace Ink Cartridges. (Press Copy/Fax then press Menu > select Maintenance and press OK > Select Ink Cartridge Replacement and press OK.)
I hope this helps.
Jul 02, 2011 | Office Equipment & Supplies
I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
follow this:
Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
Make sure that the document cover is closed, and then open the scanner unit.
Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
put it back in the printer.
Close the scanner unit, then press the OK button.
then print a nozzle check
Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
Cannot regonize ink cartridges
An ink cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
1) Make sure the Epson Stylus is turned on.
Do one of the following:
  • If your printer indicates that an ink cartridge is expended, press OK.
  • If your printer does not indicate that any ink cartridge is expended, press Setup. Then press < or > to select Maintenance, and press OK. Then press A or V to select Change Ink Cartridge, and press OK.
2) Open the scanner.
3) Open the cartridge cover.
and wait until the cartridges have moved to the replacement position.
4) Press down all the ink cartridges until they click into place to make sure they are properly seated.
5) Close the cartridge cover and push it down until it clicks into place.
6) Close the scanner.
7) Press OK to begin charging the ink. This takes about 2 minutes.
8) You'll see a message on the LCD screen when ink charging is finished.
In many cases sometimes :
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Jan 23, 2010 | Epson Stylus NX400 InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Paper Jam Clear Jam
Try this one Take out the inks and printhead Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open Close the cartridge door once the cord is unplugged Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..." Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message. Thanks Josh - Kodak Tech Support
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP Photosmart C5280 Printer
Jamming problem
try this
alternative :
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Can not get by carriage jam message
I had an old HP printer and it would say the door was open or the cartridge jam. It turned out the cartridge was too far to the end of its belt cycle. It is weird, but I put a finger space width between the cartridge and the wall of the printer and then it read it correctly. Go figure. It would get off cycle whenever I replaced the ink cartridge.
Jun 04, 2008 | HP Photosmart 2610 All-In-One InkJet...
24 people viewed this question
Ben Johnson
